anyone ever think about using PA speakers for midbass?
I ran across these really cool PA speakers, 12" with 4" coil, REALLY wide magnet... they look pretty mean. $50 each
#2 |
Yeah, in high efficient a 4way
but 3way is possible ... depends on driver ... more information is neededups, sorry didnt see its "car audio" |
#3 |
Why do people spend so much time and effort to listen to the BEP's in a phone box?
#4 |
I am using 2 X 12" Selenium PA speakers for Sub bass.........though
It's a fruitless endeavor to try and educate a fool that rejoices in ignorance
#5 |
workhorse, how does the output compare to higher excursion subs?
as far as the brand, they were in the eminence display case, there wasnt a saleperson there so couldnt ask, maybei'll go back tomorrow and try again...the spider was pretty wide so im guessing this isnt just a midrange speaker, but a midbass. whats a BEP? and whats beamwidth? |
#6 |
BEP = Black Eyed Peas, ie obnoxious noise with a beat.
#7 |
no black eyed peas here....no siree
#8 |
The trouble with PA speakers is their high efficiency would make it difficult to balance with the other speakers in the system unless of course you are going to run it active.
Using PA speakers as subs wouldn't work too well normally as they generally don't go very low, often with a Fs of around 60 - 80hz and are usually only have short travel.....
Do it once, Do it right!!!!! |
#9 | |
#10 |
Car subs typically are double that amount of excursion and even a 10in car sub can have an Fs of around 20-25hz which is far better than 60-80hz even with the gain which applies equally to both it only makes the car sub better still....
| Free-air midbass | ECM | Car Audio | 24 | 15th February 2008 12:28 PM |
| Midbass horns? | Feandil | Multi-Way | 2 | 27th April 2005 02:40 AM |
| rear deck speakers for good midbass kick | curtis73 | Car Audio | 2 | 25th October 2004 05:25 AM |
| JM Labs & Focal - Centre channel / Difference between Midrange & midbass speakers | mark.carline | Multi-Way | 5 | 18th May 2004 06:03 PM |
| which midbass would be better? | kan3 | Multi-Way | 0 | 6th January 2004 04:01 AM |
