Go Back   Home > Forums > General Interest > Car Audio
Old 3rd December 2007, 04:28 AM   #21
jol50 is offline jol50  United States
I'm not entirely clear what all is happening here, but I did have this issue with a car last year. I tossed in a system with an old 2x30w and a 2x75 bridged for a sub. The sub would bump on turn off of the key only, when radio was on. Well for this little rig I just stuck an 8ga into the fuse box for power to amps, and it was switched. That caused the amp to turn off via power loss instead of remote off. That was the entire issue. I swapped the power to an always hot source and it was fine.
Old 3rd December 2007, 05:06 AM   #22
ppia600 is offline ppia600  United States
Originally posted by I Am An Idiot
The purpose of the following is to allow your radio to stay on for a fraction of a second after the amp turns off. This will only eliminate the pop when turning the key off. If you turn the radio off you will still get the pop.
The diodes are available at Radio Shack part number 276-1661
The cap also from Radio Shack part number 272-1022
You will need to cut the switched wire going to your radio and insert this circuit.
These diodes will work with my method too. You could do this and just turn the key off but instead use the cap on the epic like I suggested.
Here is another one of my crappy atari like attempts :
Don't worry... you can always turn the gain down!
new idea? to eliminate need for BSC pforeman Full Range 26 14th June 2009 10:33 PM
Eliminate influence of switching noise from light switch in to power supply artquake Power Supplies 34 20th October 2008 05:09 PM
In order to eliminate Cms-based distortion, should Cms be... 454Casull Multi-Way 1 1st January 2007 02:05 AM
How eliminate offset voltage in my design Peter_ma Class D 12 1st March 2005 11:02 PM
Freeware Program To Eliminate Hum From Wav Files? kelticwizard Everything Else 4 3rd April 2003 03:22 AM
Page generated in 0.06358 seconds (67.43% PHP - 32.57% MySQL) with 11 queries
