Is there a way to reduce brightness of a speaker
Old 14th October 2007, 11:50 PM   #1
thermonuclear is offline thermonuclear  United States
Default Is there a way to reduce brightness of a speaker
I have a set of Soundstream 6x9's I just installed running off an MTX 4244 4 channel amp bridged stereo. They are 120w speakers. They are just too bright for my tastes. Is there anything I can do to tame the tweeters a little bit? They are extremly lound and sound good just too bright and I already have the tone control down a little from 0. I don't want to just turn down the tone because it affects the front separates as well and they sound good where they are. Can I put a cap or something just on the tweeters of the 6x9's? Or fatten the drivers up some to counter the brightness.
thanks
Arrrr I don't know what I'm doing.
Old 15th October 2007, 09:20 AM   #2
jnb is offline jnb  Australia
If the tweeter has a cap on it already, you may be able to replace it with a smaller cap. This may not be the technically perfect answer but I think it would achieve what you are asking. This could also be done by adding a small resistor in series but try the capacitor first IMO.... the effect is different.
If the tweeter does not have a cap, it may be a piezo tweeter. Adding a cap will also work but in a different way. You would want to measure the tweeter with a capacitance meter first, then add a capacitance in series that is (for starters) maybe twice that value.
Old 20th October 2007, 07:16 AM   #3
spsfahy is offline spsfahy  United States
Have you tried using a non-polar capacitor in parallel with your speaker?
Old 20th October 2007, 10:43 AM   #4
Clipped is offline Clipped  Thailand
Send a message via MSN to Clipped
the higher you go in capacitor value the less harsh it will be
try 4.7uf, 5.5 uf, 6.7uf non polar...those yellow ones...that look like they have wax on the ends
Old 20th October 2007, 04:05 PM   #5
iUSERTLO72p is offline iUSERTLO72p  United Kingdom
iUSERTLO72p's Avatar
Default Turn the darkness up!
Really, is it possible to disconnect the tweaters leads that connect to the woofer leads and go bi-amp? I used a 4 channel amp to do this, it helps when dialing in a xover frequency also gains can be upped or downed to blend better. If your going to mess with the caps maybe going bi-amped would be preferable.
L-pads could be installed if your going to take a soldering iron to them. Might be a better bet than taking away the xover set by the caps???
iUSERTLO72p
Old 20th October 2007, 04:05 PM   #6
Default See here
http://www.diyaudio.com/forums/showt...hreadid=102712
iUSERTLO72p
Old 20th October 2007, 04:43 PM   #7
Glowbug is offline Glowbug  United States
Glowbug's Avatar
Go with speakers that have silk dome tweeters
Some people just don't like metal domes...I'm one of them - my Memphis MYSNCs have metal domes that are manageable with EQing, but there's nothing quite like a smooth silk dome...
Jim
The machine does not isolate us from the great problems of nature but plunges us more deeply into them. - Antoine de Saint-Exupéry
Old 20th October 2007, 09:23 PM   #8
Hi spsfahy,
A tweeter series resistor is a must with this one, otherwise the impedance will drop near zero at high frequencies.
The capacitor should not be put across the amp.
Old 20th October 2007, 11:21 PM   #9
junglejuice is offline junglejuice  Australia
Send a message via ICQ to junglejuice
As mentioned above this is not the way to go, things need to be done properly.....
Do it once, Do it right!!!!!
Old 21st October 2007, 05:42 AM   #10
just change the capacitor or cut the wire too it...there will be no drastic effects...ive been doing it for years...
just make sure its atleats 50volts...
or just put a piece of cloth over it...
Is there a way to reduce brightness of a speakerHide this!Advertise here!
Speaker has a bit too much energy at 500Hz, how to reduce this Tino Multi-Way 7 7th May 2009 04:01 PM
What is the best way to reduce speaker cabinet volume andy2 Multi-Way 36 30th October 2008 01:51 PM
speaker surgery: reduce winding height capslock Multi-Way 1 2nd August 2004 07:49 PM
