#11 |
#12 |
The problem with an electronic (op-amp based) circuit is ground loop noise (engine noise). Unless the power supply is isolated from chassis ground or the input is balanced, you will get engine noise.
For some simple circuits, you can allow the op-amp supply to ground through the shields (this was relativley common about 20 years ago) but the current passing through the shields can cause noise in other components that are driven off of the same RCAs. The transformer based mixer is probably the best for what you're trying to do.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#13 | |
i had this problem when i built a LM386 preamp and installed it in a car,. I got a power line filter that took care of the noise |
#14 |
A power line filter won't work in most cases. The noise isn't caused by ripple on the power line. It's caused by a ground loop.
| Stereo to mono... | mcelaj | Solid State | 12 | 17th December 2011 04:57 PM |
| mono vs. stereo | schmalex | Chip Amps | 1 | 6th June 2005 01:51 PM |
| Stereo vs Mono | profuse007 | Car Audio | 4 | 6th March 2005 08:25 PM |
| stereo to mono | janey | Solid State | 3 | 12th December 2001 05:57 AM |
| Page generated in 0.08056 seconds (76.14% PHP - 23.86% MySQL) with 10 queries |
