Go Back   Home > Forums > General Interest > Car Audio
Old 11th October 2007, 05:53 AM   #1
Default I need some Identification help on this audio setup
I believe the woofer is a Cerwin Vega. Whats the rest of it? Iv been trying to figure this out for a long awhile now. Any ideas?
Thanks.
Old 11th October 2007, 07:58 AM   #2
Send a message via ICQ to junglejuice
That is a Cerwin Vega "stroker" sub, on the left and right hand side panels are custom made passive crossovers, on the vertical wall is a pair of Phoenix Gold Stiffening capacitor units that were mounted inside amplifier heatsinks that matched up with the MS series of amps (from memory) and at a guess though it is hard to see I would say that the amp is a Phoenix Gold MS-xxx.....
Do it once, Do it right!!!!!
Old 11th October 2007, 09:49 AM   #3
Oh wow. Thanks for the quick reply. Looks like im going back to the drawing board for this.
Old 11th October 2007, 03:08 PM   #4
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
I'm doubting it is a stroker.
1st, it has a different top spider. (CV uses flat top spiders)
2nd, the frame is chromed. (I don't think chrome is the fad when strokers came out)
3rd, the surround is also different. (the orig stroker uses corrugated surrounds from PA sub designs from what I recall)
4th, there's no nipple. (the 'nipple' is where you adjust the front spider position)
probably an audiobahn modded to have a front spider?
or that this is indeed a CV but I have never seen a stroker that looks like this.
Old 13th October 2007, 04:24 AM   #5
Clipped is offline Clipped  Thailand
Send a message via MSN to Clipped
if its not a stroker, then it may be an earthquakes balls (or different series), planet audio also made a sub with a top spider.
but if that car is using amps from that era, stroker would be the closest thing in that time frame.
Old 13th October 2007, 04:31 PM   #6
spooney is offline spooney  United States
planet audio used to make a stroker knock off as well. I believe it was called the FU series
everyones audio setup? pat99 Car Audio 35 23rd January 2008 02:31 AM
car audio sub in an HT setup gompka Subwoofers 4 30th December 2005 03:07 AM
In Car Audio Setup HELP!!! zorb_rules Car Audio 6 28th June 2004 10:57 AM
Audio Setup Help Tweak Car Audio 10 17th June 2004 07:07 PM
$1000 for car audio setup griff Everything Else 6 4th April 2002 08:50 AM
Page generated in 0.08200 seconds (75.31% PHP - 24.69% MySQL) with 10 queries
