I have a a2300hct audiobahn amp. I was hooking up a battery isolator using the same remote turn on lead as the amp so they would come on at the same time. The car was off but the amp was still hooked up. When i used a positive wire from the battery to turn on the isolator and test it, i heard a crack from the amp. I thought i unpluged the remote from the amp while i was testing the isolator, but i didn't. All the fuses in the amp blew, so i replaced them. As soon as i put the first one in the amp caught on fire. I took it apart and one of the smaller transistors blew up. I'm trying to find a replacement transistor but i dont know how to match the numbers. The amp has about 30 transistors half small and half larger. The one that blew up was a smaller one. This is what is one the face of the transistor.
IRFZ48V
I*R 306H
3D 17
The pic is the half with the small transistors.
Thanks for any help.
IRFZ48V
I*R 306H
3D 17
You can't simply replace the single transistor. You must replace all of them that are in the same supply as the one that blew.
You need to check the ones in the other supply also to see if any have failed. Measure the resistance between the first and second legs of each power supply transistor. None should read near 0 ohms. If they do, the transistor is defective.
After you replace the FETs, you need to power up the amp through a 10-15 amp fuse (in series with the B+ supply line). Clamp all of the transistors to the sink BEFORE applying power. If there is another fault, the new FETs can fail within seconds. If the transistors are clamped to the sink and you use the small fuse, the new parts will likely survive and you'll only have to find the other fault. Without these precautions, you'll also have to replace the new parts (again).
Since you have to order parts, I'd suggest ordering a new power supply driver IC (TL494/594?) and new driver transistors (marked a1266 or a1023?).
If you pull all of the defective power supply FETs and power it up, you can do a few tests to determine if the power supply driver circuit is working properly.
Safe_Cracker said:It is an audioblah amp, is it really worth it in the price of parts? Polo..
I'm definately not a fan audiobahn, but some people have been known to pay $150 to get 'em repaired.
I have also a strange problem with the a2300hct. Tha amp starts in normal blue mode but i dont have sound, the fans are not working and the one power output indicator shows +3db (left). The right one is at 0. I have checked the wiring but its ok. It must be an amp fault!!!!!!! The amp was working fine with no problems, awesome sound but one day started to make this. The 4 fuses are ok. Is my amp blown or is something else?
Thanks for the response!!!!!!
The amp has a power output indicator. It has -40 -30 -20 -10 -5 0 +3db
The left one shows +3db the right one is -40 now. Every time the amp is pushing power it goes from -40 to -10 or to 0 etc regularly. Now the left one in continuasly +3 db and the right one -40. It should be both -40 at the beginning when not much power. So if the left channel shows +3DB it has too much power in the left channel and in the right one is normal. I will check again the wiring and the amp seperately.
Take a digital multi-meter and set to DC voltage, take your black meter lead and place it on the left - terminal and take your red lead and place it on the left + terminal and tell us what your meter reads. This is done with the amp powered on but with the volume turned all the way down.
- General Interest
- Car Audio
- blown a2300hct audiobahn amp (need help!!)
