diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Car Audio (http://www.diyaudio.com/forums/car-audio/)
-   -   Old phillips car amps with din input jack (http://www.diyaudio.com/forums/car-audio/109758-phillips-car-amps-din-input-jack.html)
IrishboyM4 9th October 2007 06:20 AM
I have a pair of Phillips car amplifers that are about 20 years old. give or take 2 years. I need a din connector to run them properly. Does anyone know how to make up a din for the amp. THe model number is en2100 100Wx2 into 4 ohms.
I Am An Idiot 9th October 2007 03:55 PM
Get an ohm meter and go buy the din plug you need and we can help. Let us know when you get the plug.
IrishboyM4 9th October 2007 10:46 PM
I got the plug and i already have a fluke 112 ohm/ampere meter.
I Am An Idiot 10th October 2007 10:29 AM
Connect the negative meter lead to the ground terminal of the amp. Set the meter to the ohms. If it is not an auto-ranging meter you set it to 20K scale. Touch the red meter lead to each pin of the din plug. Post the results here. Pin 1 = ___ Pin 2 = ___ Pin 3 = _____ and so forth.
jacco vermeulen 10th October 2007 10:59 AM
5-pin DIN
I Am An Idiot 11th October 2007 03:14 AM
Also need to know if there is a remote wire with the power and ground connections? Or would it too ve in the din plug?
IrishboyM4 11th October 2007 03:29 AM
There is a remote wire. The din should come out to 2 RCA plugs and a remote power on wire.
Resources saved on this page: MySQL 18.75%
