Please forgive me for this seemingly unintelligent question but I was perfecting my cartoon drawing skills during high school mathematics class.
I have been told that an angled box is good for a sub as it reduces the direct back pressure. This is apparently more of an issue when the box is smaller than the optimal box size. I have a 15" DVC Option Audio subwoofer as can be viewed here . I have been told that it should go into a 61L sealed box for optimal response. After being quoted $300+ for a custom box I sought out to get a pre-fabricated box. I am looking at this item in eBay but I have a few questions:
Personally I favour smoother frequencies with ultra low bass and plenty of space between frequency bands. Thanks in advance ~groover |
#2 | |
You break the box into seperate sections. The box is a rectangle, with 2 triangles on top. You should minus the thickness of the wood from the outer edges also. For this application the angled box will not make any difference.
#3 |
An angled box doesn't reduce the back pressure, but it spreads the standing waves over a broader freq range. In a rect box, when the inside box dimensions are equal to half the sound wavelength, you get standing waves. With the angles, you like have many small standing waves all of slightly different freqs.
But as noted above, at LF the wavelengths are so large that they are always (much) larger than the internal dimensions anyway, so the angles don't make a difference. Edit: I believe 'litrage' is commonly called 'volume' in English Jan Didden
/Yes! Its out: Linear Audio Vol 5! I'm not an "accademic", just a plodder who loves a challenge - Ian Hegglun |
#4 | ||
I would be most likely be applying a low pass filter that leaves a gap from where the 6x9s roll off. I like to listen to downtempo styles of music whilst driving. This music often skips large 'chunks' of frequencies offering more at the extreme low and the extreme high. A well mastered piece will often have your mind hearing the in between frequencies without them being present or requiring much of the tracks available amplitude. |
#5 | |
If the triangles are equal, you can put them (in your mind) together so they form a rectangle. Then it's just the product of the sides of course. If they are not equal, you can pretend each consists of two equals, calculate the volume, and divide by two, for each triangle. Jan Didden
#6 | ||
Bracing myself...I don't claim to know anything so please be gentle
#7 |
haha so bleeding obvious! thank you janneman. Please excuse me whilst I go beat my chest and forage for food... |
#8 | |
Oh and if someone could please comment on
#9 |
Just use some acoustic mat on the inside if you're worried about that. You could glue some 3/4 inch carpet underlayment to the walls, for example. You know, that recycled foam mat they use under home carpeting. They sell it at hardware stores by the square yard. You can also find acoustic foam similar to the stuff they use in record studio walls but with trianglular projections and glue it to the walls. I think parts express or mcm sells the stuff
Don't worry... you can always turn the gain down! |
#10 | |
| XLS 12 sub in 50 litres / 26Hz + 200W BK amp - any better suggestions for ~£250? | alexclaber | Subwoofers | 5 | 21st December 2007 06:50 PM |
| litres to box size | damianl | Multi-Way | 30 | 7th September 2007 10:40 AM |
| If I use 1g dammping fill Vb1= Vb - xx litres | DariusM | Multi-Way | 3 | 13th December 2005 08:08 PM |
| The 55 Litres challenge !!! | richardkrol | Subwoofers | 7 | 10th March 2004 11:21 PM |
| Are angled braces necessary? | PWatts | Multi-Way | 5 | 17th July 2003 10:58 AM |
