Hi guys,
I have found this old Autotek 7300 BTS amplifier from the store and was told that it's a very good set to use. The problem is the female molex connector jack is no where to be found and without it, I cannot power up the amp. Does anyone have details with regards to the functions of each pin on the molex connector so I could build a molex female connector for the amplifier without frying it? Thanks in advance! |
#2 |
pic attached.
#3 |
If you pull the cover, the speaker wires should be marked. The orange is remote.
The amp is brigeable so if the markings don't tell you if they are positive or negative, the left signal wire is positive. The right signal wire is negative. Those will be connected to two different points on the board. The two speaker wires that go to the same point on the board are the left negative and the right positive. If I'm not mistaken, the positives are next to the remote in the plug. If you don't want to pull the cover, check for continuity between the pins in the plug. One of the two that are directly connected (0 ohms), will be next to the remote (the only filled center socket in the plug). That's the right channel. The right negative is directly below it. The other side of the plug is obviously the left channel. Since you don't know the condition of the amp, power it up through a 15 amp fuse. It should play at a low level. If it does, you can change the fuse to the one recommended for the amp.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#4 |
Haha, I've had one of those amps sitting in my closet for months because the owner hasn't returned my messages. I'm going to give him a little longer and put it up on ebay, as is
Here's a pic of the plug, right side up:
Don't worry... you can always turn the gain down! |
#5 |
That is not the correct plug for that amp. That is a Rockford plug that has been modified.
The following is in reference to Maxfire's picture. The 3 pins on the bottom row are the positives. The 2 pins on the top are the speaker negatives. Top left pin is Right - Bottom left pin is Right +. Top right pin is Left - Bottom right pin is Left +. Center pin is remote
If it ain't broke Don't fix it |
#6 |
hey guys,
thank you very much for your help!
#7 | ||
Hi guys,
From what I have gathered from the forum and elsewhere, there seem to be some discrepancies. With reference to my attached image which I have posted earlier, I would like to highlight on the LEFT top + bottom, and the RIGHT top + bottom pins. According to I Am An Idiot's post: Quote:
![]() The green cable (top left) is said to be LEFT(-) and the white cable (bottom left) is said to be LEFT(+) which is contrary to I Am An Idiot's post. The only thing I am sure now is the top side pins are (-) and the bottom side pins are (+). Can someone please enlighten my doubts ? Thank you ! |
#8 |
According to the first picture you posted the top left pin is the Right channel negative wire. The pin directly below that (closer to the BOTTOM of the pic) Is right channel positive wire. Then we move ovr one pin to the right and that would be the remote wire. (that is the pin in the middle of the bottom row). Now if we move one pin to the right of the remote, that would be the Left channel Positive wire. The pin directly above that would be the Left channel Negative wire.
#9 |
Hope this helps
#10 | ||
Hi ! It definitely helps! Thank you! Does that also means that I can safely ignore the colour codes of the cable and pictured as below ? Quote:
![]() The information I got from the picture's cable colour and the quote from another forumer tells the following picture: ![]() Sorry if I kept asking the same question, just wanted to be sure.
| How to connect molex/ multipin connector | lgreen | Construction Tips | 10 | 25th August 2009 12:26 AM |
| Molex part in stock | peterchen88 | Vendor's Bazaar | 0 | 7th September 2007 03:45 PM |
| Autotek 7600bts | electropro | Car Audio | 2 | 28th January 2007 03:03 AM |
| autotek MM1000.1D | xtremesound | Class D | 0 | 22nd February 2006 11:52 PM |
| Molex 100mil flat cable interconnects | jackinnj | Swap Meet | 0 | 6th November 2003 05:47 PM |
| Page generated in 0.14352 seconds (78.55% PHP - 21.45% MySQL) with 11 queries |
