I am trying to return this amp to life to use it in my car due to it's size (it fits perfectly!). And more time I spend on it, more problems I discover and less I want to drop this project...
The deal is: couple of blown FET's in class-D section, ALL blown FET's in both power supplies (I think this amp was killed twice lol), shorted rectifier and, of course, completely burned 4700/75 capacitor, which made it through the board with 2" hole in diameter Board is multi-layered, and traces inside the board are damaged too I did my best to restore them, but it's hard as hell.Amp now starts (both power supplies ok), slightly clicking relay and switching LED from orange to green. All outputs are not shorted. It is doing the same with driver boards removed. Is a schematic for this amp available? I already spent too much time on this project to abandon it |
#2 |
If the power supplies are not shutting down, check the output of each channel to see if there is any reason for the amp to be going into protection. Look for DC offset on the output of each channel. If there were shorted outputs, look for damage to the overcurrent protection (generally a transistor and resistor across the emitter/source resistors They generally have a diode connected to ground also).
If there is no reason for the amp to go into protection, the problem is likely in the protection circuit.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
| knock off Belle Klipsch? | capt mike | Multi-Way | 12 | 6th December 2009 07:00 PM |
| Belle Canto opera recordings | jp_howard | Music | 0 | 18th April 2009 02:13 PM |
| FS/memphis belle mb-17 6-channel 1200 watt at 2-ohm beast | ncamps | Swap Meet | 0 | 14th April 2009 01:01 PM |
| Meet belle lab, a new manufacturer of single driver fullrange loudspeakers | cdwitmer | Full Range | 14 | 11th September 2005 06:23 AM |
| Page generated in 0.05443 seconds (76.63% PHP - 23.37% MySQL) with 10 queries |
