Well in my other post I indicated that my amp died due to water. It is a lanzar 360 watt amp (2 channel). I am probably going to upgrade my amp to a larger one and through in some better subs (the pyramid subs that came in the box suck ***) - don't laugh was trying to keep things within a budget, but cheap doesn't sound that good
If I can fix it I will probably through it in my wifes car with a small box in the trunk - though I know she won't go for that I don't have an O-scope, but is it possible to trace it through with a top of the line voltmeter (does other stuff as well). If so where do I start and should I be looking for obvious things when I open it? Thanks. |
#2 |
I fix amps full time for a living like Perry does. If hes busy just e-mail me. I also have a bunch of amps you might like. LMK ...
#3 |
You need to pull the amp apart to determine if the board is salvagable. It couild be too badly corroded to repair. You need to remove the board so you can inspect both sides.
Before you begin, go to page 20 of my car audio site. It's a repair primer that I put together (still under construction). It will help familiarize you with an amplifier's general layout.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
| DHD should repair? | Solosound | Car Audio | 5 | 9th November 2008 07:39 PM |
| my amp repair | benlebow | Car Audio | 3 | 10th February 2008 12:30 AM |
| Nad 304 repair | big jim | Solid State | 0 | 30th December 2006 11:19 AM |
| CDM 9/44 to repair CDM 9 Pro | Duson | Digital Source | 1 | 12th October 2005 04:41 PM |
| Help for repair my KSA 100 | Alex helge | Solid State | 76 | 23rd October 2003 03:38 PM |
| Page generated in 0.07256 seconds (68.61% PHP - 31.39% MySQL) with 10 queries |
