Go Back   Home > Forums > General Interest > Car Audio
Old 29th September 2007, 08:07 PM   #1
Default Alpine CDA-9811 issues Where to start?
I have a Alpine CDA-9811 head unit that worked great until I put it in my friends car for a test. It worked in there, but now I have no output from the speakers in my system. This is from the amplifier that is built into the unit.
I checked the menu and the ams are turned on, I have it on the bench right now to check but do not know were to start looking for the problem.
None of the outputs are working and the heatsink on the back of the unit gets warm (not hot) which makes me think that the amplifiers may be working but in somekind of a mute mode?
Are there internal fuses in this head unit that I can check? I did reset the system. Could there be an issue with the face plate that is causing this? I assume that it is working correctly because it beeps when I go into the setup mode, but, the tuner up and down buttons seem to be acting up (the tuning does not move when I press them)
I cannot afford to buy a new head for my car and this should be an easy fix, but I cannot seem to find schematics on it (less buying from e-bull)
Thanks for your time,
Jeff
Old 29th September 2007, 10:54 PM   #2
Is there an AI net switch on the bottom of the radio?
If it ain't broke Don't fix it
Old 29th September 2007, 11:22 PM   #3
Yes there is, it is set to normal (not eq/div)
Old 30th September 2007, 12:26 AM   #4
If you have a volt meter, set it to the DC volts selection and check from ground to each speaker wire, one at a time of course. You should have about 6 volts on each of the 8 wires. If you have 10 volts on one wire and a volt or 2 on the other 7 wires, you have a bad output chip.
Old 1st October 2007, 12:28 AM   #5
Thanks for the help,
I did the check with my voltmeter and I am getting between 6.18 to 6.20 volts on all of the speaker pins.
Does that rule out the output device?
Old 1st October 2007, 12:59 AM   #6
Yes that pretty much rules out the chip itself. Go back through the menu and make sure the AMP-IC function is still on. 9815 is AMP-IC, it might have a different name on the 11. Also if the switch on the bottom got switched you may have to unplug the harness or reset the radio.
If none of that works, do you have any way to check the RCA outputs? headphones and a stripped Patch cord? a jam box with AUX input?
Old 1st October 2007, 01:52 AM   #7
Thanks!
The amp is set to on, I have tried the ai-net switch both ways, reseting the unit each time. I have it running on a modified PC power supply so I can kill the power at any time. I just hooked it up to a old pioneer stereo that i have down here and there is nothing coming out of the front or rear pre-outs.
Old 1st October 2007, 03:17 AM   #8
ppia600 is offline ppia600  United States
Wow... is there a cell phone mute wire that could be somehow grounded, or maybe the amp turn on wire was grounded in your friend's car and caused some kind of internal problem??
Don't worry... you can always turn the gain down!
Old 1st October 2007, 05:34 PM   #9
any ideas what kind of voltage should be on the pink/black wire? I will check to see if it is shorted to ground.
Old 1st October 2007, 07:28 PM   #10
No idea what voltage is on that wire but I am pretty sure the display reads Interrupt if it is interrupted. Like PPI said check for 12 volts on the remote and power antenna wires.
Alpine 5.25 Car Speakers FS vdi_nenna Swap Meet 0 11th December 2008 07:53 PM
Will start my new Gainclone from Start, Need Help samsagaz Chip Amps 4 27th May 2008 09:39 AM
is this an alpine amp? jol50 Car Audio 30 29th April 2008 03:11 AM
Alpine MRV-F345 channel 2 issues zozom3 Car Audio 1 23rd July 2007 03:05 PM
PPI vs. Alpine smokeaway Solid State 2 28th August 2005 10:51 AM
Page generated in 0.09898 seconds (77.56% PHP - 22.44% MySQL) with 10 queries
