ive been stuck in old school for so long now, that i realized that im not even sure what current day rail voltages are for various wattage amps.
so if you have a few examples including rail voltage, brand, wattage, class, minimum load, etc... id appreciate it. thanx |
#2 |
I can't give you a list but in one amp I had on the bench, it had 315v DC across the rails. It was either a DD 5000 or a Goliath.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
If it ain't broke Don't fix it |
#4 |
I haven't measured the rail voltage on my amps, but I have measured the maximum no-load output voltage on a couple
Linear Power 2.2hv - 135x2 @ 12.5v, 185x2 @ 14.4v (2 or 4 ohm selectable), max output voltage 33Vrms per channel when set to 4 ohm. I assume the rail voltage is around 100V damn...I thought I had masured more than just the LP, lol Well my Crown CE-1000 home amp has ~170V rails and I measured the no-load output voltage at 60rms per channel, rated at: 275x2 @ 8ohm 450x2 @ 4ohm 560x2 @ 2ohm But it's not a car amp well maybe in the next few days I'll try to measure my Cadence or Arc. |
| Rail voltages from 15-0-15 volt transformer | Bama Slamma | Power Supplies | 3 | 26th November 2006 10:27 AM |
| the best transformer rail voltages for gainclone? | araven | Chip Amps | 2 | 30th September 2006 10:31 PM |
| bosoz rail voltages | EANDERS | Pass Labs | 2 | 25th March 2005 04:19 PM |
| Amp supply rail voltages.... | Xicarius | Everything Else | 2 | 4th August 2004 12:38 AM |
| help with rail voltages | Svetlana | Pass Labs | 11 | 24th June 2004 09:35 PM |
| Page generated in 0.07886 seconds (72.27% PHP - 27.73% MySQL) with 10 queries |
