Go Back   Home > Forums > General Interest > Car Audio
Old 22nd September 2007, 09:33 PM   #1
spooney is offline spooney  United States
Default Phoenix gold xs2500 blowing fuses
I've found 2 bad irf540s in the output section on the left channel so far. I'm just kind of curious as to exactly what else i should check before i make a parts order? Is there another component that commonly goes out on this amp or any amp when the outputs fail?
Old 23rd September 2007, 02:04 AM   #2
Check the 6 and 15 volt zener diodes in the channel, along with all other signal diodes, and all of the little transistors all the way back to the input of the channel from the rca board.
Then re-solder the big Grey resistors < these get hot and the solder goes bad>
Old 23rd September 2007, 02:19 PM   #3
Thanks for your help man.You and Perry never hesitate to spread your knowledge.I hope I can repair amps like you guys someday
Old 24th September 2007, 05:56 AM   #4
Thank you for those kind words. I'm sure Perry appreciates them also.
I own PG equipment, so I am biased, and I fix PG equipment all the time for others. I just repaired a channel on a XS-2300 last Friday, its the same amp just a bit smaller. PG scales there amps just like other companies.
Old 25th September 2007, 11:09 PM   #5
can i use any irf540 as a replacement? I see on digikey that there are a couple different irf540s that have various current and power ratings.
Old 26th September 2007, 01:16 AM   #6
I use IRF540N as my choice for replacement.
Old 15th October 2007, 11:54 PM   #7
well i replaced the irf540s and the amp worked great....... for about an hour.It was playing at moderate volume and didn't seem to be overly hot or anything when some of the power supply fets gave out along with the small resitors near them.The newly replaced irf540ns survived. I feel bad because i was repairing this for a buddy at work and it was working great and then nothing.Is it possible that when the outputs gave out originally that it caused some harm to the power supply fets that I obviously missed?
Old 16th October 2007, 02:37 AM   #8
Anything is possible depending on the load and volume he was driving.
Its more likely that the bias circuitry for the damaged channel might have made the channel pull excessive current, or the input was damaged and now that damage is causing excessive current draw on the supply while operating.
I hate to say this but I generally replace all the transistors and the zeners in a bad channel. I realize this is shot-gunning the amp but I have much higher success with this method of repair on these amps.
These are designed rather unusual with a unique zener regulated bias circuitry. I find when they go, they are GONE, and for the extra 2 each 6 volt and 2 each 15 volt zeners, and a few MPSA-06 and 56 SST's I just get better repair and lower rework rate on these exact amps.
I would replace the power supply and test the amp by watching its idle current and output bias levels and DC offset numbers with no signal applied to the amp, and no load. If the amp is stable it will just set there after normal warm up and idle soak < about 30 minutes > and there will be no unexpected rise in any of the readings. If it past that idle test i would run the amp at 30% power level and recheck the amps setups to see that they temp tracked properly.
My first lessons on these amps were painful as yours is becoming, but after a few reworks I found that I had overlook several different issues in the channel that caused it to run way out of spec very quickly after warm up.
Hope this helps...
Help with Phoenix Gold EQ215x Messerschmitt Car Audio 3 27th April 2008 05:55 PM
Phoenix Gold Ti mod. / upgrade 100db Car Audio 9 5th October 2007 04:49 PM
Phoenix Gold Octane-R R12 in HT sub? moving_electron Subwoofers 2 23rd January 2004 03:59 AM
Phoenix Gold, worth considering??? Javaman Multi-Way 3 30th January 2002 10:31 PM
Page generated in 0.09901 seconds (77.25% PHP - 22.75% MySQL) with 10 queries
