BX1000D with no output?
Old 14th March 2009, 04:47 AM   #21
Perry Babin is offline Perry Babin  United States
If both read approximately the same, you only need to do it for one. If you're unsure, do it for both.
Old 14th March 2009, 05:21 AM   #22
79twotone is offline 79twotone  United States
Send a message via AIM to 79twotone
I tried to resize the pics to make sure they're readable
Old 14th March 2009, 05:33 AM   #23
If this was out of the board, both are defective.
Old 14th March 2009, 05:45 AM   #24
Those weren't removed from the board. I'll try to get those removed first thing in the morning and re-test them.
Old 19th March 2009, 05:43 PM   #25
Quick question, is it necessary to remove the board before removing and reinstalling parts or will I be fine with the desoldering pump and iron? May be a dumb question but remember I'm new to this.
Old 19th March 2009, 05:51 PM   #26
If you can get them out of the board from the top without damaging the solder pads, you don't need to remove the board.
If you've replaced the FETs, do not apply power to the amp with the driver transistors out of the board.
Old 31st August 2012, 07:14 AM   #27
gorillakev is offline gorillakev
3 years old thread I wondered what happened maybe I should carry off on this thread or start a completely new one. I have the same exact problem but its on my 1606d. Let me know if I should start a new thread just like the original poster not new to car audio but way new to repairing amps.
Old 31st August 2012, 07:28 AM   #28
Mooly's Avatar
Probably best to start a new thread detailing all you have done and checked etc
BX1000D with no output?Hide this!Advertise here!
Hifonics BX1000D Dobermann Car Audio 2 26th September 2008 04:27 PM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 06:15 PM
Help needed on modifying BX1000D Marty45 Car Audio 4 10th July 2004 05:14 AM
Hifonics Brutus BX1000D problems... Knertified Car Audio 1 7th July 2004 12:34 AM
I2S digital output in Marantz CD4000 and four TDA1541A with balance analog output iklari14 Digital Source 30 18th July 2003 12:57 PM
