BX1000D with no output? - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 18th September 2007, 07:09 AM   #11
Send a message via AIM to 79twotone
Actually all of the output transistors look fine, but all 8 of the power transistors are fried. But I think I'll take your word for it and replace them all just to be on the safe side. Still waiting on a response from maxxsonics to find out what model power transistors they are. I'm guessing there TIP41C, because the numbers on the transistors weren't found on any of the electronic parts sites. Thanks again...I'll still try to get some pics up by the end of the week.
Old 18th September 2007, 09:14 PM   #12
They may look like a TIP41 but believe me they are not. What are the numbers on them that you can't find on your electronic parts sites?
If it ain't broke Don't fix it
Old 19th September 2007, 01:40 AM   #13
This is just just what one of them says...F M()339 F()P 65N()6. I'm guessing that they could be 0's or Q's but they're just ()'s on the transistors. I found a FQP-65N06 part number for mosfets. Maybe thats what they could be.
Old 19th September 2007, 02:14 AM   #14
The FQP65N06 is a commonly used power supply transistor. Mouser has them.
I suggested replacing the outputs earlier but after reading your more recent posts, I'm not sure which transistors have failed (other than the power supply transistors). Don't replace any parts until you've done more troubleshooting.
Old 19th September 2007, 06:31 AM   #15
Yeah its kind of hard giving info without pics, but I'm away from my digital camera until the end of the week, and cell phone pics are crappy. But thanks again for the help. This is truely a learning experience.
Old 24th February 2009, 04:10 AM   #16
Its been a while but between school and work, I haven't had much time to work on the amp but I'd still like to try to repair it. Here are some pics of the amps internals, oh yeah and sorry about bringing this post back from the dead
Old 24th February 2009, 04:19 AM   #17
Did you check the output transistors to see if any are shorted? They are the ones on the left (4 top, 4 bottom) in the overall photo of the amp.
Old 24th February 2009, 04:32 AM   #18
I've actually only checked the obvious so far which were the FQP65N06's which were the ones that were damaged. The output transistors(F1310N's) which I'm guessing are the ones at the other end of the amp look fine. After reading through one of your old post you said I may need replace the FQP65N06's and the HIP4080 IC
Old 24th February 2009, 04:54 AM   #19
If there are no shorted output transistors, the HIP4080 is probably OK and won't need to be replaced.
You also need to remove and check the PNP driver transistors. One is between the transformer and the power supply FETs. It's D-shaped (looking at it from the top) and is adjacent to a diode and resistor. I can't see the one on the other side. You need to pull both of them and check them. If you don't know how to check them, use the form below and post the screen caps (instruction in the panel at the left of the form).
http://www.bcae1.com/repairbasicsfor...estpage02.html
Old 14th March 2009, 05:37 AM   #20
When checking the transistors using your page would I be checking each one all six ways recording the values for each?
Hifonics BX1000D Dobermann Car Audio 2 26th September 2008 05:27 PM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 07:15 PM
Help needed on modifying BX1000D Marty45 Car Audio 4 10th July 2004 06:14 AM
Hifonics Brutus BX1000D problems... Knertified Car Audio 1 7th July 2004 01:34 AM
I2S digital output in Marantz CD4000 and four TDA1541A with balance analog output iklari14 Digital Source 30 18th July 2003 01:57 PM
Copyright 1999-2017 diyAudio
