Go Back   Home > Forums > General Interest > Car Audio
Old 11th September 2007, 05:31 AM   #1
Default JBL 300.4 amp upgrade/mods
Im new here and wondering if u guys can help me with the options that I have.
MAIN PCB
ICO-00-00022
I.C PWM IC "DIP 14"
TL494CN
U1
ICO-00-00109
I.C QUAD OP AMP "DIP 14"
NJM2058D
U101,102,103,104,105,108,109,110
ICO-00-00003
I.C DUAL OP AMP "DIP 08"
TL072
U111,112,113,114
ICO-00-00095
I.C DUAL COMPARATOR "DIP08"
KIA393P
U801
What about power cap, is it advisable to change it too?
Old 12th September 2007, 12:01 AM   #2
ppia600 is offline ppia600  United States
You need to specify what you are hoping to achieve by trying to "upgrade", maybe that will clarify it for the people here who might know if its possible
Don't worry... you can always turn the gain down!
Old 12th September 2007, 05:03 AM   #3
i would like to tweak the amp to be used specifically for midrange and tweeter usage. (better in mid n highs)
i hope i can get more transparent in the sound n less floor noise
Old 12th September 2007, 07:02 AM   #4
Easy, Bypass the entire IC frontend, and run straight input to the main amplifiers on the board. Most of your troubles will be generated by all the IC's in the frontend.
PS leave the 494 and 393 IC's alone, they are power supply control chips, No audio there.
Old 13th September 2007, 04:12 AM   #5
thanks
i do hv the service manual does it help?
should i replace the cap inside?
Old 13th September 2007, 06:18 AM   #6
Only if its defective , If you store excessive power inside the amp it could actually cause noise on shutdown unless the amp is muted properly.
Please remember if its not broken it does not need fixing.
Armed with this you will save yourself tons of money and time and effort..
Old 26th September 2007, 06:34 AM   #7
whats the options that i have if i would like to upgrade the op amps in terms of sq and audiophile quality?
CD: Copland CDA 266 mods / tweaks / upgrade yagoolar Digital Source 13 5th April 2011 10:11 AM
Proac Studio200 - Upgrade mods help needed stu.dio Multi-Way 2 21st November 2008 02:19 AM
41Hz AMP2 upgrade... What parts to upgrade? MotoMan_Yz400 Class D 2 6th March 2008 05:28 AM
Muse Model 2 DAC upgrade with Guido Tent DAC upgrade? jpchleapas Digital Source 1 31st January 2008 07:18 PM
What upgrade for the job? Rarkov Solid State 2 16th June 2003 05:05 PM
Page generated in 0.10338 seconds (78.05% PHP - 21.95% MySQL) with 10 queries
