Go Back   Home > Forums > General Interest > Car Audio
Old 5th September 2007, 08:48 AM   #1
Default help needed installing head unit!
Well, what should be a relatively simple process has now consumed a day.
My car has no stereo (daihatsu charade 1994 5 door hatch) but all the wiring is there.
So my dad gives me the old head unit from his car and some speakers and i take to installing it. I match the correct wiring from the loom to the head units cable and turn the key....nothing happens.
After several hours of trying and trying i decide it is the head unit.
So i buy a new one.
Same result.
I've tested the cabling and power is getting through but neither head unit is turning on.
Any ideas?
Old 7th September 2007, 09:19 AM   #2
Dan2 is offline Dan2  South Africa
there should be 2 +12v input connections. one connects directly to the battery (permanent 12 volts to save the settings when the head unit is turned off) and the other input to the ignition( so the head unit turns on when you turn the key) there's also a remote output( used to turn on amps etc)
Head unit greg928gts Car Audio 9 10th June 2009 07:26 PM
head unit basenjifan Swap Meet 0 24th September 2007 07:58 PM
Looking for a head unit with eq (and XO) xplod1236 Car Audio 41 20th April 2006 12:01 PM
Head Unit VoLCoM Car Audio 4 31st October 2005 03:51 PM
Page generated in 0.10951 seconds (42.48% PHP - 57.52% MySQL) with 10 queries
