Go Back   Home > Forums > General Interest > Car Audio
Old 28th November 2007, 05:35 PM   #91
http://bcot1.com/images/rca/temporar...eldrepair.html
Old 28th November 2007, 05:43 PM   #92
So your saying that the no ohm value means I have an open ground? I checked the HU while in the dash. Should I have pulled it out? Thanks again.
Old 28th November 2007, 05:54 PM   #93
You should have approximately 0 ohms when you touch one lead to the RCA shield and the other lead to the case of the head unit.
You need to do this with all RCA cables disconnected from the head unit.
Set the meter to the lowest ohm range. Touch the leads together to make sure the meter is working properly. You should read 0 ohms when you touch the leads together.
Old 28th November 2007, 06:16 PM   #94
OK. I will double check again later.
I do remember connecting the rca shield to ground and the noise got even worse, but I only did it with one of the rca outputs.
Thanks.
**Oh, is this a common occurance? Why would HU manufacturers fuse the ground, and not just run a solid trace?
Also, my preamp outputs on the Jensen HU are about 6" wires straight out the back that end with an RCA plug. I noticed the pictures you had were a little different. Should I break the insulation and solder to the shield, or should I solder a line off the rca shield as you depict?
Old 28th November 2007, 06:43 PM   #95
Was the EQ still in the circuit when you grounded the RCAs?
Without fusible shield grounds, if the RCA cables contact the main power wire, the RCA cable will burn from one end of the vehicle to the other. It's a fire hazard. This used to be relatively common before the shields were fused. I see a lot of people who pull their amp but don't pull the main power fuse and don't tape up the power wire. While driving, the wires (RCA cables and power wire) slide around in the trunk. Eventually they make contact.
Don't cut the insulation. The connection is between the RCA patch cable connector and the case of the head unit.
Old 28th November 2007, 06:46 PM   #96
I don't remember if the EQ was still in the circuit. How would that make a difference? Thanks again!!!
Old 28th November 2007, 07:03 PM   #97
If the EQ was in the circuit and was defective, repairing/restoring the shield ground of the head unit could not stop the noise because a second defective component was in the audio chain.
Old 29th November 2007, 02:13 AM   #98
Hi. I checked the ohm value again and it did not register. I temp grounded the rca shield to the HU housing and then plugged it into the amps via a split cable. The wire grounding made no difference, you could still hear the slight buzzing/whine through the mids, tweets, and barely through the subs, with the volume all the way down. Maybe its just my vehicle?
Old 29th November 2007, 05:09 AM   #99
ppia600 is offline ppia600  United States
Oh My Gosh... I thought you tested the head unit's rca grounds a long time ago Ding, ding, ding. I sure hope they are actually fried, that will probably take care of everything. We've been all running a wild goose chase
Don't worry... you can always turn the gain down!
Old 29th November 2007, 10:53 AM   #100
Unplug the RCAs from all components on both ends. Make sure none of the ends are in contact with the vehicle or anything that is conductive. Measure the resistance from each of the shields of the RCA cables to chassis ground (black lead on a known good ground). You should read infinite resistance. If you read something near 0 ohms, the RCA cable is pinched/shorted to ground.
On the head unit end, ground both/all RCA shields to the head unit (I'm not sure if you have more than one RCA cable going to the rear of the vehicle). They have to be grounded. You can't do any troubleshooting with ungrounded shields.
After you have the shields grounded, plug the RCA cables into the highs amp ONLY. Does it have noise?
Unplug it from the highs amp and plug the RCAs into the sub amp. Does it have noise?
Need help troubleshooting whine in speakers roger2 Car Audio 5 19th May 2009 05:22 PM
Help! t-amp in car, alternator whine ractis Car Audio 4 25th February 2006 05:51 PM
'03 Accord - Alternator Whine Pete H Car Audio 5 30th June 2005 04:02 AM
Engine whine feelinhipp Car Audio 3 13th March 2004 05:53 AM
Can someone help me with alternator whine? Timbers Car Audio 14 23rd February 2004 05:14 PM
Page generated in 0.10286 seconds (86.07% PHP - 13.93% MySQL) with 10 queries
