The whole boot/trunk for E.B.S The whole boot/trunk for E.B.S - diyAudio
Old 4th September 2007, 05:51 PM   #1
mikee55 is offline mikee55  United Kingdom
mikee55's Avatar
Default The whole boot/trunk for E.B.S
Hi all, with a Longmill 10", I could do a nice 100l box of extended bass shelf. That takes up most of the space in my hatch. Could the whole of the boot/trunk be utilised?
My main concern is to still be able to use the space for carrying, so maybe if I made the whole of the boot/trunk, a cabinet, whats best to be able to hinge a panel with the trunk/boot door to make it possible to chuck the shopping in there, when needed?, do you follow?
Cheers
Mike
If it don't work, I'll fix it in the mix! Or visit http://lsdp.proboards.com/index.cgi
Old 4th September 2007, 10:06 PM   #2
mikee55's Avatar
Default more info
I was thinking a hinged panel, a tight clamping clasp of a sort with a rubber seal around the perimeter to make air tight. Clasp similar to front loading washing machine door?
Any takers?
Mike
Old 5th September 2007, 12:07 AM   #3
Perry Babin is offline Perry Babin  United States
It should work well. You could make the top or part of the top removable. Rubber hood latches (link below) should be quiet enough. The number required would depend on the power used to drive the woofer and the size of the removable cover. Closed cell foam weather stripping would seal it well.
http://www.speedwaymotors.com/p/1581...ood-Latch.html
Old 5th September 2007, 09:33 AM   #4
mikee55's Avatar
Default Thankyou
Cheers Perry Babin, I'll look into those.
Mike
The whole boot/trunk for E.B.SHide this!Advertise here!
Too much weight in the trunk, please help? TwoThirteen Car Audio 4 7th September 2008 12:18 AM
PC doesn't boot Devil_H@ck Everything Else 41 8th June 2005 08:41 PM
need a sub for ~22.5 cu ft trunk xplod1236 Car Audio 6 31st January 2005 01:19 PM
Boot build Ryancowe Car Audio 0 1st April 2004 01:40 PM
Copyright ©1999-2017 diyAudio
