problem with subs or amp problem with subs or amp - Page 2 - diyAudio
Old 8th September 2007, 01:35 PM   #11
fearless_gamer is offline fearless_gamer  United States
well i figured out the problem with it, i got a new amp and installed it and it did kinda the same thing but then i had figured out that the ground wire on the amp was loose and the Y adapters on the back of the cd player were causing it...but i got a new amp so i dont have problems... it a sony xplod xm-2002gtw 1200 watt, sounds much better than my old one.. i am very surprised with the amp since its a walmart amp but it sounds really good..
Old 8th September 2007, 03:26 PM   #12
ppia600 is offline ppia600  United States
Glad to hear it
Old 8th September 2007, 09:14 PM   #13
but something i noticed last night and today, every now and then ill hear like a "pop" type noise come from the rear passenger side..
Old 9th September 2007, 03:01 AM   #14
We need more details on how your equipment is installed
-are the speaker soldered to the wires?
-are the speaker terminals touching the metal of the car?
-what brand rca cables do you have?
-is the amp running your highs and if so, how are the wires ran to the speakers?
-how are the radio's wires connected to the speaker wires, if there are any the deck is running (crimps or t taps, or soldered?)
If I was there to see it, we could have it figured out in less than five minutes... nothing much I can do over the interweb...
Old 9th September 2007, 01:42 PM   #15
no the speakers are not soldered, the amp is only running the subs, the deck is powering the rest, dont kno what brand the rca cables are, think tey might be monster, the deck is connected to the harness with butt conectors and plugged into the factory harness...didnt happen til i put in the bigger amp, i was thinking maybe the pressure from tthe subs was messin with the stock 6x9..
yes you ar very right, it is hard to help fix somethin or figure somethin out when you cannot actually see or hear what is going on..
Old 9th September 2007, 03:40 PM   #16
Try turning the deck bass down low and then adjusting the amp back up to get the subs back to the volume you want. Maybe the subs are pushing on the 6x9's like you said and working against the deck causing distortion. Sometimes using a capacitor inline with the speaker +'s will help. Something between 45 and 99 uf, unless your deck has a high pass filter for the front and rear, then you could use that. What model number is the deck? Should be on the faceplate somewhere. Something like cdx-.....
Old 10th September 2007, 01:20 AM   #17
its a sony xplod CDX-C410X
problem with subs or ampHide this!Advertise here!
Any problem crossing stereo 12" subs at 150Hz? Dumbass Subwoofers 44 2nd April 2006 09:25 AM
Convert floor standers to subs with Tang Band 8" subs? prerunnerv6 Subwoofers 3 26th February 2006 12:44 AM
2 subs one box/2 subs 2 boxes vetkilr Subwoofers 5 22nd February 2006 09:27 PM
Which amp for my subs? paulspencer Solid State 6 28th July 2004 07:49 AM
All you with DIY subs Howard Subwoofers 7 4th January 2004 06:38 PM
Copyright ©1999-2017 diyAudio
