Go Back   Home > Forums > General Interest > Car Audio
Old 28th August 2007, 06:04 PM   #1
genes66 is offline genes66  United States
Default xtant a2002 amp
do you know what component can cause a buzzing sound in a amp?with power hooked up but no speaker and no rca cables attached
Old 28th August 2007, 07:26 PM   #2
The transformer is generally the only component that will make any noise. Many times, you can touch it or twist it and the buzzing will stop.
Old 26th February 2008, 06:40 PM   #3
Default xtant a2002
there is a buzzing noise coming from inside of amp when volume is increased do you know what causes this?
Old 26th February 2008, 07:48 PM   #4
jol50 is offline jol50  United States
I only had one audiobahn that did that, but if it is the power supply it should stay the same. I guess if you load that amp and it is regulated it could change as the PS ramps up. The AB I had to have the cover off and my ear right next to the transformer to hear a static type sound. it seemed to work fine though, I could find nothing wrong with it and with the fan going and cover on I could not tell. I'm not sure what else besides a transformer would buzz in an amp, guess I would take a look and try to locate it or use a piece of wood/plastic rod by ear.
xtant 604 x mike49504 Car Audio 8 29th November 2008 08:00 AM
xtant A2002 amp burnt? hbch Car Audio 1 12th November 2008 10:52 PM
Xtant 3150c kelwin Car Audio 4 23rd October 2007 09:58 PM
Xtant 604X / 2 ohm sub jimeez Car Audio 1 10th January 2004 05:35 AM
Page generated in 0.07743 seconds (70.98% PHP - 29.02% MySQL) with 10 queries
