Go Back   Home > Forums > General Interest > Car Audio
Old 25th August 2007, 05:24 PM   #1
Angry audiofonics 800w 2channel subwoofer amplifier
someone please help me!!!!! aaaarrrrggggghhhhhh!! i installed an 800watt 2 channel audiofonics sub amp in my friends mitsubishi outlander. the red protected light is on and none of the fuses are blown, even the main fuse connected to the battery. i checked all the wiring from the headunit back to the sub and amp, nada as far as anything damaged. my friend did mention that the cooling fan was making a loud noise and then simply quit working as well as the amp. what should i do besides going office space on this p.o.s. i'm open to any suggestions at this point. could the fan not working trip some sort of kill switch and is there any way to bypass this. i looked online for a replacement cooling fan but had no luck finding the right size and power. please help!!!?!!!
Old 25th August 2007, 07:33 PM   #2
If the amp goes into protection, it's likely that there is a defective component. Ths most common reason for amps to go into protection is shorted output transistors.
It's unlikely that a defective fan would cause the amp to shut down unless the amp overheated from insufficient cooling.
Old 27th August 2007, 03:15 PM   #3
Thumbs up THANKS ALOT!!
thanks alot, that helped me regain my sanity. i tried to tell my friend that but he insisted it was the cooling fan. i told him that if the fan quit then it would cause the amp to overheat and might damage it. he wanted me to run a rockfosgate 12" sub off of it bridged and i suspect he cranked the gains up and fiddled with the lp filter after i installed everything. what make and model amplifier would you recommend for 2 12" rocks in a sealed enclosure ran in a series?
SMPS 230 VAC to 115 VAC 800W TeeJay Power Supplies 88 22nd September 2011 07:30 PM
active subwoofer and 2channel amp. calvin14 Parts 4 16th July 2009 04:08 PM
Alpine type r and a 2channel stereo amp drtydvn Subwoofers 1 12th November 2004 05:58 AM
300-800W 8Ohm Sub Amplifier KostasTheGreat Solid State 23 24th August 2004 03:02 AM
Need info on building 2channel version of Outlaw 750 MannyE Solid State 0 11th December 2000 06:27 PM
Page generated in 0.07397 seconds (73.04% PHP - 26.96% MySQL) with 10 queries
