Hello,
i'am new here and my english ist not very good i have a problem with my 4 Channel Amp µDimension 420.4. I hear some distortion when i hear for example pianomusik and guitar (no e-guitar) it's terrible If i have radiorushes (no receipt) on the amp and set the Lowpass 200Hz, i hear some scratches as with a dirty vinyl. I tested already much. - another HU - another Car - another Speaker with a laboratory power pack is it the same. Its definitely the amp. which problems could be the cause? I'am a electrician, but here i don't know more. Please give me some Tip, thanks! Greetings, Martin |
#2 |
I'm not familiar with that amp but if this is an amplifier that has the RCA shield tied directly to the center tap of the power transformer's secondary windings, an open trace between the shield and the center tap could cause the problem.
If the problem is not the same in all channels, the problem could be a dirty switch or potentiometer but it's likely you would have noticed this when moving the various controls.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
#4 |
I have found a discrepancy.
The rail for 2x -15V and 2x +15V have 4 condensers pro rail. 3 rails have 100µF an 1 rail have 220µF ![]() perhaps come the problem because of different sieving? i have after the operation ampflifiers with a amplifier and a loudspeaker attached and i have hear no distortions. distortions are only at the exit (loudspeaker connection) of the amplifier PS: the amp is new, but no warranty -> exhibition piece before nobodoy use ist |
| ar.com dimension question | Bobhof | Multi-Way | 6 | 23rd April 2006 06:23 PM |
| PP OPT Core dimension | silurato | Tubes / Valves | 4 | 28th April 2005 09:42 PM |
| anybody tried http://www.acoustic-dimension.com ? | dcg69 | Parts | 17 | 20th April 2005 07:41 PM |
| PMC XB2, MB2 vent dimension | gengis | Subwoofers | 1 | 23rd March 2005 10:02 PM |
| Cut Out Dimension For 12" Pioneer | Tony.ca | Car Audio | 0 | 27th February 2004 07:32 PM |
| Page generated in 0.08381 seconds (74.56% PHP - 25.44% MySQL) with 10 queries |
