Go Back   Home > Forums > General Interest > Car Audio
Old 24th August 2007, 01:21 AM   #21
You said earlier that the voltage on leg 3 of Q30 would drop when you applied remote voltage. The jumper will prevent the voltage from dropping (assuming that the trace is damaged/corroded under the caps).
Old 24th August 2007, 01:28 AM   #22
genes66 is offline genes66  United States
Default zapco
you are correct about that sorry!! now i understand. what is Q30 used in the circuit for?I have another ag 350 hooked up in car that works can i use it to troubleshoot this amp i am trying to repair? iam worried about possibly damaging the good one any suggestions?.
Old 24th August 2007, 01:31 AM   #23
Leave the good one alone.
The next hing you need to do is to connect the jumper (fused) across those points.
Old 24th August 2007, 01:41 AM   #24
Default zapco
i will get some fuses tomorrow and do that and give you the results thanks for all your help
Old 24th August 2007, 03:43 PM   #25
Default zapco ag 350 car amp
hey i ran a jumper like you told me and the power led came on whats next ? you said replace caps does it matter who makes the caps and what brand do you recommend?
Old 24th August 2007, 08:10 PM   #26
You need to pull the capacitors so you can examine the board and the caps. If there is an odor that smells like antifreeze when you apply heat to the terminals of the capacitors, there is electrolyte on the board and that means the caps must be replaced. This is likely what you'll find.
I'd suggest the FC series capacitors at Digikey.com. You'll need to measure the diameter, height and lead spacing to get the correct capacitor. Do an initial search like this (replace the values with the ones from your capacitors):
capacitor FC 1000uf 35v
Then go to the catalog pages for each cap to see which fits your amp.
You will need to run another jumper permanently. It doesn't need to be fused. The fuse was to help prevent additional damage in case there were other problems.
Old 24th August 2007, 11:22 PM   #27
Default zapco
i have to run a jumper from d6 and d7 to Q30 permanantly?why?
Old 24th August 2007, 11:36 PM   #28
twon007 is offline twon007  United States
or can't he just get a trace repair?
Old 25th August 2007, 12:48 AM   #29
The jumper replaces the trace that's likley been eaten away by electrolyte. The trace is under the capacitor. There is no practical way to repair the trace since the cap must sit directly on the board. The original trace was only ~0.002" thick. Virtually any repair will be much thicker. The jumper is the only practical repair.
When you run the permanent jumper, you should tack it to the board at several points with an adhesive. This will prevent it from moving which would eventually lead to it breaking near the ends.
Old 25th August 2007, 05:28 AM   #30
Default xtant a2002 amp
sometimes it cuts off and you can hear a buzzing inside amp i opened it to listen cannot trace wear sound might be coming from maybe caps its hard to say does any one know about this
HELP!! Looking for Zapco oldshoolaudio Car Audio 6 22nd June 2009 09:57 PM
zapco ag 350 genes66 Car Audio 2 28th August 2007 01:31 AM
Zapco Z400C4-SL scott-leanne Car Audio 23 13th May 2006 07:44 PM
Zapco SX-SL Processor.... ? coogj1 Car Audio 2 4th February 2005 02:22 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
