kicker 352xi resistors across output burned, what resistance?
Old 18th August 2007, 01:27 PM   #1
ppia600 is offline ppia600  United States
Default kicker 352xi resistors across output burned, what resistance?
I have a kicker 352xi. It works but across the two output leads on the circuit board there is some type of filter that consists of two capacitors and two resistors. Both resistors are burnt beyond recognition so I can't read the color code. I've seen it happen on another amp before, but only one was toasted so I was able to read the other. They are the same resistance because of their symmetrical location. Does anyone have one of thes laying around they could check the color code for me???? Thanks
Old 18th August 2007, 05:46 PM   #2
Perry Babin is offline Perry Babin  United States
They are most likely 4.7 ohms.
Old 19th August 2007, 02:45 AM   #3
Default Thanks
Sounds familiar.. I'll check around to see if I can find any other info otherwise, but if not I'll throw some in. They are 1/4 watt anyway
Brian
kicker 352xi resistors across output burned, what resistance?Hide this!Advertise here!
kicker 352xi resistor spaz1980 Car Audio 4 9th August 2009 06:09 PM
JL 500/1v2 amp Burned Resistors stevepersell Car Audio 15 28th April 2009 10:29 PM
polk componets & Kicker 352xi amp Failure skooter Car Audio 9 4th September 2008 10:00 PM
Kicker ZR1000 mosfet burned... xbcaraudio Solid State 2 10th March 2004 08:44 PM
