About the real power of an amplifier.
Old 17th August 2007, 11:01 AM   #1
dex13 is offline dex13  Bulgaria
Question About the real power of an amplifier.
Hi all,
Some time ago I bought a subwoofer speaker Hertz HX 200, 4ohm, 8". It was stated 300W continuous power, 600W peak. I measured it at 50Hz and I don't think it can handle more than 25 Volts RMS (35V peak), which is about 150W RMS.
Now I look at the amplifiers and the cheapest one (Blaupunkt GTA-280) offers "RMS power (4 ohms) 1 x 210 W". Hm... what should I expect from this amplifier? Will it be too much for this speaker or these 210W RMS are not RMS calculated in this way?
Please excuse my bad English, and thanks in advance for your advices.
Regards.
Old 17th August 2007, 11:33 AM   #2
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
Look if it's continuous rating at 20-20kHz and what battery voltage. Being Blaupunkt it's probably quite accurate rating.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 17th August 2007, 12:44 PM   #3
I found only this in the manual: RMS power in accordance with CEA-2006 (< 1% dist. / +14.4V)
Old 17th August 2007, 01:15 PM   #4
Did it Himself
That is a good sign.
Old 17th August 2007, 01:23 PM   #5
acid_k2 is offline acid_k2  Italy
An ampli rated 210W RMS at 14.4V can drive a 8" 300W speaker.
For "quality" audio listening, trim ampli output at normal-low level....
For "boom boom" audio listening, trim ampli output at more high level, and pray your subwoofer doesn't fire...
About the real power of an amplifier.Hide this!Advertise here!
a dream...real audio current amplifier.... menekken Solid State 13 5th November 2007 04:42 PM
real beginner amplifier inadaze Solid State 8 10th May 2007 04:45 AM
Real brute power amplifier ostie01 Solid State 9 1st August 2006 09:53 AM
My first real amplifier Solid Snake Solid State 18 5th June 2003 01:27 AM
real RMS power Dj BASS AMP Multi-Way 8 17th April 2003 01:35 AM
Copyright ©1999-2017 diyAudio
