#11 |
Picture this
Cheers Mike
If it don't work, I'll fix it in the mix! Or visit http://lsdp.proboards.com/index.cgi |
#12 |
Just put fuse in an fired it up. It takes place of my Maystar QXT455 4 channel amp rated 150w @13.8v x2 into 4ohms(both my amps are 2 ohm stable) . The JBL manual doesn't quote a figure, none the less it shows a picture and is bridgeable. Also its says 2/1 channel amp on the case and manual. I wired both ways and found the percieved loudness to be more or less the same, yet my Maystar bridges louder?
As for this one in the lounge, I got it fed by a 40hz 24dB Linkwitz R crossover and Linkwitz Transform @20hz, which richie00boy helped me to build. The amp is powered by a PC power supply and its problem is, when the bass goes really low, even with volume down, the speaker sort of squeeks??? The Protection led does not alter in anyway, it doesn't dim, even the fan on the PSU doesn't slow. Got me baffled. Thats 4ohm on a 2 ohm stable amp also. Any thoughts? Mike
#13 |
this
#14 |
How are you?
#15 |
Did it Himself
Hi Mike, I'm OK but not got much internet access until September as I'm working away.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#16 |
I'm just pee'd off with my squeeky woofer. The GTO was dead, its no resurrected. I was curious how it would sound in the car. Will find out soon. The Maystar, I'm going to wire up after work. I've posted a sound file over on subwoofer threads. It was recorded with an MP3 stick, 20quid job, but the squeek is clear. There seems to be plenty of volume and nuffing else. Hope you can here it. I still want to buy one of your amps, but I have to knowif the Transform is correct. If the Maystar doesn't improve matters, I will reverse enginner with the spreadsheets and check the circuits calculations. When I built Linkwitz's circuit using his values, that driver rumbled and the cone flapped in and out and the room filled with low stuff, you could tell it was reaching low. And thats with the wrong values. So maybe I've got something wrong. I've no idea whats up with email. We're moving house soon, in a few weeks, and I ain't going with Orange, will be looking for another ISP. Who do you choose?
Don't work too hard. Regards, Mike
| Leak 2000 Question | ix66 | Solid State | 2 | 9th September 2008 06:31 PM |
| bridge rectifier question | crippledchicken | Power Supplies | 31 | 25th April 2008 11:17 AM |
| Grounded Bridge Question | rtarbell | Solid State | 3 | 22nd June 2006 07:05 PM |
| Bridge Rectifier Question | sam9 | Solid State | 3 | 16th October 2004 01:03 AM |
