Go Back   Home > Forums > General Interest > Car Audio
Home Forums Articles Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Thread Tools
Old 11th August 2007, 03:46 AM   #1
coki is offline coki
Default car antenna
I am replacing my car standard head unit and is locating the connector to the car radio antenna.
First, there is no external antenna on my car.
Second, there is a connector that I think is for the antenna but it has a small circuit board and 4 pins connector.
Any body knows anything about this?
Old 11th August 2007, 04:34 AM   #2
MadMutt is offline MadMutt
What rock have you been hiding under ?
That IS the connector.
Anttena will be an 'in glass' one.
That circuit will be an anttenna amplifier.
Old 11th August 2007, 08:34 AM   #3
OK MadMutt. I probably have been too long under that rock in Alice Spring
Now, I supposed I have to connect 2 of the pins to the car battery and 2 the the antena input? I have done that and the reception is still not that good. How can I improve this?
Old 11th August 2007, 11:35 AM   #4
Ditch the whole set up and install a 'normal' antenna.
Active antennas are a joke (my thoughts).
If the signal is weak, then the 'amplifier' is also going to increase the noise.
Not sure about the pin connections.
Maybe some else here will be able to help out.
What sort of car ??
And if you were 'hiding' under 'Ularu' then you would either be;
1. very flat.
2. claiming land rights.
Thread Tools
FM antenna coldcathode Everything Else 6 16th June 2009 05:20 PM
DIY antenna Fry-kun Analog Line Level 3 24th May 2007 08:52 PM
FM Antenna jaya000 Car Audio 5 27th January 2007 04:40 AM
Antenna ? fortuosity Everything Else 1 17th October 2005 10:14 AM
What do you think about this antenna ? darkm4n Parts 0 6th March 2004 09:47 PM
Page generated in 0.06998205 seconds (78.33% PHP - 21.67% MySQL) with 10 queries
Copyright ©1999-2010 diyAudio
