#21 |
ok that was verry informative. thank you. actually, how many volts do you think i am to have for the led on? i have 6+. does this sound right? with it removed?
#22 |
With the LED in the circuit, you shouldn't have more than ~2v across the LED. If you have 6v, the LED is likely damaged. With the power LED out of the circuit, I'd expect ~15v.
If you don't have 15v with it out of the circuit, measure the voltage across the power supply pins of the op-amps. There should be ~15v from the power supply pins to ground and ~30v from one power supply pin to the other.
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#23 |
["hello there my name is teddy ruxpin. will you be my friend?"]
had to get that off chest. lol. the mpsu devises were used in front of the power supply in this amp. but nethertheless it is working great now. very louuuuud! |
#24 |
Don't ever sell that thing. I made the mistake of selling one a few years ago on ebay.. I think I only got like $275 for it.
I just saw one sell for about $350 but IMO that is WAY too low for an amp that puts out so much clean power. I miss mine, haha
#25 |
this is a very beautiful peice. well i love old ppi anyway. had the 2300 am and the oldschool jbl gti1000 subs and that was nice. to tell you the truth, i didnt get to put this one on anything that could handle it. did this do good for a sub amp?
#26 | |
Does it ever??? The damping is amazing and the power is definately there. I would get another if I wasn't trying to keep them bolted under the seats, its a long amp. |
#27 |
heavy too! hey do you happen to know why the low imped light comes on if i push the briudge button? there was a problem with the fan lead shorting out and blowing remote on transister,fiuxed thius and the red on-led. now this happens.???? thisu ius wiuth no speakers hooked up.
#28 |
I don't remember a "bridge" button.???? Mine only had dual voltage range switch, hp/lp, crossover on/off, and the crossover frequency range and gain controls. One pair of inputs and one pair of outputs I believe. Mine never had the low impedance light come on.. Do some checking, you might still have a bad output transistor somewhere. I don't know if the amp will totally shut down or just run hotter if that happens. The only problem mine ever had was with the main tranformer touching between two wires. All I had to do was move them and epoxy away. Good as new.
| PC 2350 power supply - a little help | Ampdoc | Car Audio | 3 | 2nd September 2007 03:50 AM |
| Behringer CX2310 for Dayton/Vifa at 2350 KHz ??? | G Laframboise | Multi-Way | 1 | 9th October 2006 05:16 PM |
| eqt not powering up! | marko | Car Audio | 9 | 22nd August 2006 11:37 PM |
| Powering a car amp | soundNERD | Car Audio | 14 | 29th June 2005 03:40 AM |
| 15th anniversary PPI PCX-2350 Blown. | djp | Car Audio | 1 | 6th June 2005 02:53 PM |
