Do the legs of a darlington serve the same purpose as bi-polars?
what exacty is the difference in operation between a darlington and bi-polar? what woud it take to convert a bi-polar amp to darlington based amp? like in my other post i want to try switching devices and see what happens. the darlingtons im thinking of are the BDW93/94 combos to replace BD909/910 devices. what other modifications would be involved in doing this? repaired an Audisn amp a while back and was blown away by the sound, although i know the outputs arent the only pieces in the chain, i just want to experiment. thanks again |
#2 |
All darlingtons are bipolar, but bipolar is not necessarily a darlington.
http://en.wikipedia.org/wiki/Darlington_transistor For an amplifier, you might be able to substitute a darlington for an existing single BJT, but it might not give you any improvement. A darlington will have a greater voltage drop, and given the same load, will dissipate more heat. There are also other issues, such as capacitance and speed, that should be matched to satisfy the overall design. If you do want to throw in a darlington, attempt to match characteristics as much as possible. Choose darlingtons that are recommended for audio use. |
#3 |
hi zigzag, thanks for the info, it is a good primer for some good reading!
| Darlington Resistor | Steve Eddy | Solid State | 3 | 7th January 2009 05:34 PM |
| Darlington pair | Tualek53 | Parts | 9 | 16th August 2005 07:54 AM |
| Darlington and Triple darlington | lumanauw | Solid State | 78 | 1st December 2004 12:57 AM |
| What is a darlington output exactly? | mjarve | Solid State | 4 | 18th July 2004 01:28 AM |
| Can I make a Non-Polar Electrolytic using two polar ones | PaulHilgeman | Parts | 6 | 10th February 2003 12:07 AM |
| Page generated in 0.07345 seconds (73.14% PHP - 26.86% MySQL) with 10 queries |
