Go Back   Home > Forums > General Interest > Car Audio
Old 16th July 2007, 07:11 PM   #1
nakkor is offline nakkor  United States
Default to port or not to port
i recently purchased a Cerwin-Vega 12" V-max sub. it is a dual 2 ohm speaker that can handle 600 rms..(not too shabby imho) it will be driven by a Cerwin-Vega EXL 1000D that puts out 500 rms...my friend let me put it in his ported box, in which it slammed, or should i keep the speaker in the sealed box that i build to CV air space specs even though it isn't as loud, and doesn't seem to be as responsive to my broad range of music taste....i know box type is generally personal preference, but any insight that yall could give me would be great..
Old 17th July 2007, 04:22 AM   #2
Clipped is offline Clipped  Thailand
Send a message via MSN to Clipped
port it ! and adjust the port length to your musical taste.
Old 17th July 2007, 06:42 AM   #3
CV doesn't seem to give any T/S parameters for their drivers, which is pretty much a must-have IMO. Try calling them maybe? Although I wouldn't be surprised if they refused to give you any pertinent information.
IMO, if you want the BEST sound from a subwoofer in a vehicle, large ported enclosures usually aren't necessary, mainly due to the massive cabin gain. In fact, the best setup I've ever heard was IB with the back seat removed, and other's opinions seem to confirm this.
Anyway, let us know how it works out when you need further help. But until you get some fairly accurate T/S specs to toy around with, any success with this project is just a shot in the dark.
CERWIN-VEGA!
Customer Service and Technical Support
Monday-Friday 8am-5pm MST
Phone: 1-480-838-9422
Fax: 1-480-491-1201
Shipping Address:
Attn: Customer Service Department
6965 S. Priest Drive
Suite 5
Tempe, AZ 85283
Old 17th July 2007, 08:33 AM   #4
Default t/s specs
this is the link to speaker specs.....they hide it well
http://www.cerwinvegamobile.com/manu...Sub_Manual.pdf[/URL
with those specs, any suggestions on whether or not it should be ported?
Old 17th July 2007, 08:33 AM   #5
btw it is in a 92 mazda extended cab p/u, if that makes a difference...
Old 17th July 2007, 09:16 AM   #6
Did it Himself
richie00boy's Avatar
Qts is borderline at 0.46, I would tend to suggest a sealed box.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 17th July 2007, 10:30 AM   #7
Yep, I'd try sealed first with this one..
*edit* - But as far as the woofer itself goes, vented is just as doable.. Just thought I'd make that clear.
I kept trying to figure out why WinISD was giving me a crazy EBP of like 500-600, but soon realized that CV put a typo in their own PDF, lol. QES is .52, not .052!..which is impossible anyway. Afterwards, we get an EBP of 51.9. Anyhoo, for the given T/S, WinISD suggests a sealed enclosure of .717 ft^3 (20.3 l) for a .71 Q with an F3 of around 41 Hz, and -10dB at 24 Hz. If you ever get stuck on wanting to try ported afterwards, WinISD suggests a 1.507 ft^3 (42.7 l) enclosure at 23.61 Hz for flattest response with an F3 of about 22 Hz, and -10dB at 18 Hz. Group delay peaks at 32.83ms @ 21.26 Hz. Of course, this is all disregarding the 12 dB/octave cabin gain, which plays a very significant role in the final response of the system. And being an extended cab pick-up truck, the gain will even be slightly higher.
Hope this helps.
~ Brandin
Old 17th July 2007, 11:53 AM   #8
Did it Himself
The trouble is going to be physically incorporating a wide enough vent to tune a 43 litre box to 24 Hz. That is why I recomended sealed
Old 17th July 2007, 07:45 PM   #9
thanx much....hopefully i get use to the sealed sound, and if it just isn't enough for me.......maybe i'll go up a model or 2 to the stroker or stroker pro....lol.....but thanx again...
Old 17th July 2007, 09:15 PM   #10
..I wouldn't suggest a Stroker.
Rear port and front port barry.childs Multi-Way 10 27th February 2009 09:46 AM
Slot port vs circular port equivalence Brisso57 Multi-Way 12 21st February 2009 02:38 PM
Single Port Vent Better than Dual Port? Daveis Multi-Way 18 15th July 2007 05:12 AM
To port or not to port? Newbie with newly built mains starquake Multi-Way 1 18th December 2004 12:51 PM
rear port vs front port Jimmy154 Multi-Way 22 6th March 2004 08:38 AM
Page generated in 0.11647 seconds (79.00% PHP - 21.00% MySQL) with 10 queries
