i am having problems with a sony xm-754hx 4 channel amp. at first it faulted out for over current and i replace one channels pair of output fets that were shorted (irf540 and irf950 with irf540n and irf9540n.)
what is the "n" for? was this swap ok? now the amp draws 20 amps of current upon power up with no audio signal going to it but the over current light is not on any more. strange? i suspected the power supply fets because they read almost shorted from gate to source on all 4 of the fkv550's. when i pulled them they all tested fine on their own but the meter still beeped constantly from the pads where the gate and source would be on the board. i looked for any bad solder joints or charred components but everything looks fine. what could this be? what else should i check? Thanks in advance for any suggestions. |
#2 |
Sounds like the fet gate drivers are toast Maybe... The channels could still be blown in front of the fets you replaced and if so your turning the amp on into a over drive condition that would draw 10 or more amps.
I would remove the outputs and retest the amp for idle current. and then take voltage readings at the gate for the output fets to see what kind of drive signal they are getting. Good luck
| Sony DTC-790 dat problem | dukasound | Digital Source | 2 | 3rd October 2008 05:33 PM |
| CD changer Sony CDX-601 problem | LevyB | Car Audio | 2 | 25th September 2005 09:47 AM |
| Sony V-Fet Amp TA-N7B problem | Bernhard | Solid State | 62 | 2nd March 2005 12:28 PM |
| sony amp problem | supes | Solid State | 3 | 1st February 2003 08:09 PM |
| Page generated in 0.07124 seconds (68.59% PHP - 31.41% MySQL) with 10 queries |
