Go Back   Home > Forums > General Interest > Car Audio
Old 10th July 2007, 10:37 AM   #1
msm677 is offline msm677  Philippines
Default BC517 replacement
Any replacement for BC517 (silicon planar epitaxial darlington transistor complimentary to BC516)? I cant find any store here in philippines that has this.
please help me. thanks.
Old 10th July 2007, 11:38 AM   #2
acid_k2 is offline acid_k2  Italy
Try this one: MPSW45
Datasheet: http://www.onsemi.com/pub/Collateral/MPSW45-D.PDF
It's difficult to find an equivalent transistor, BC517 has a very high Hfe...
Old 10th July 2007, 12:41 PM   #3
if i'm going to replace BC517 with MPSW45, should i replace all the other BC517 in my amplifier? I think I have 4 or more of them
Old 10th July 2007, 03:43 PM   #4
between MPSW45-D and 2N6426, what will I choose to replace BC517? or are there any suggestion(s)? please help me.
thanks.
Old 11th July 2007, 11:36 AM   #5
I think MPSW45A and 2N6426 are similar to BC517, both are good.
If you are repairing an amplifier, you have to replace necessarily all BROKEN components!!!
If you have to build a new amplifier, replace all BC517 with an equivalent one (MPSW45A or 2N6426)
Attention: pin configuration of MPSW45A and 2N6426 is different from BC517!
Old 11th July 2007, 05:24 PM   #6
I'm repairing my old earthquake pa-4050c amplifier? I tried finding these 2 transistors and none here sells this kind. any suggestion or replacement for BC517? please help.
Old 12th July 2007, 12:21 PM   #7
Default Last attempt
-1- try finding them in internet shop of your country or near your country...
-2- look at the attached picture:
a darlington transistor is 2 transistor "in series" to obtain an high gain, so you can try that:
-find 2 normal NPN transistor, 1A, 40V,
-connect the pins like the schematic in the picture,
-you have a typical darlington transistor...
Good luck
Old 12th July 2007, 03:02 PM   #8
Default Re: Last attempt
Good luck
thanks, i'll try it.
Replacement LED DreadPirate Parts 11 14th November 2009 04:45 PM
Replacement amp for A-Bus? Greg911 Class D 0 16th November 2008 02:33 PM
MTX 5 ch pot replacement pk386 Parts 2 1st October 2006 04:32 AM
Replacement for 5R4 Ralph Tubes / Valves 8 16th December 2003 10:02 AM
Page generated in 0.09487 seconds (79.12% PHP - 20.88% MySQL) with 11 queries
