Go Back   Home > Forums > General Interest > Car Audio
Old 9th July 2007, 05:04 AM   #1
microp is offline microp  Latvia
Default Smps 36-0-36 500w
Hi!
I want to create SMPS.
I have this schematics (pic)... and ETD49 core. I place of MTP75N06 will use four pairs BUZ11 or IRF 540.
Will it be enough with ETD49 for 500W?.... or how much power can produce this core?
If it is right ....how many turns and what kind of wires should I use?
Thanks!
Old 9th July 2007, 09:24 AM   #2
luka is online now luka  Slovenia
luka's Avatar
Send a message via MSN to luka
Hi
Buz11 would be ok, but I would go for irfz44.
It depends on what freq. you will go for....
You should go for minimum of 4 turns for primary.
home page @ http://www.classdaudio.co.cc @ 24/7 all year long
I FEEL SLOVENIA
Old 9th July 2007, 06:24 PM   #3
Default Thanks for answ.... but ...
could the core hold 400 to 500W? I will set any frequency needed by this core... as I heard ~50khz is good for this!?
Old 9th July 2007, 07:04 PM   #4
luka's Avatar
Hi
If you will go for 50kHz then core will probably be capable delivering ~900W, so I would go for around 30-35kHz so that you have minimum skin effect
I FEEL SLOVENIA
Old 9th July 2007, 07:11 PM   #5
Default Thanks!!!
You are fast!
May be you could tell me what wire should I use in primary and secondary to produce 500W.
regards
microp
Old 9th July 2007, 07:33 PM   #6
luka's Avatar
Hi
Well I can't realy help you there, because I don't know what wire you have/can get. I have 0.5mm dia wire and make my own litz wire. cross section of those wires has to be as big as from single wire rated for that current. Assuming 500w and 13v input voltage there will be 40A going in each primary, so each pri must be rated for that current or more. Same with secondarys.
I have added a pdf, which has a table where you can see what wire can conduct what current. So I look for "single wire, open air". This is because I think you will be using this smps for audio, and the load is not 100% at all times, so you can afford this. So for 40A, wire has to be a bit less then AWG 12, or 0.08" in diameter. If EU this is 2mm. Whis wire has cross section of 3.25mm^2. So you should use xx wires in parallel to get this cross section. You do same for sec. I you will use ETD you will peobably put both PRI first and then both SEC.
I FEEL SLOVENIA
Old 9th July 2007, 08:21 PM   #7
Default Thanks!
Wires I can get all diameters... its no problem... now I know all to build SMPS
Only problem is to figure out how to set it to more output voltage than 35... as I know SG3525 can operate not more than 35... but i don't want to remove feedback because I don't know will my amp hold the unload voltages... they are much more than 35 without feedback... or maybe I am wrong!?
Old 9th July 2007, 08:36 PM   #8
luka's Avatar
Hi
What are you tolking about. If you are building it for car, then SG will be powered from battery(12-14v). You can get any output voltge you want, even if a lot more then +/-35v. Transformer ratio will have to be changed, but that not a big deal.I would use feedback, so you can get high power without any sag in output voltage. Do you have any schema of what you are trying to build?
I FEEL SLOVENIA
Old 9th July 2007, 08:57 PM   #9
Default Just beginner.. sry!
I have read one thread about voltage... where the voltage is growing when lower load attached. I don't know... just gathering info...
You are the best of all informs because answers are correct and short!!!
Thanks!
Old 9th July 2007, 09:00 PM   #10
Default .....
Here it is!
Power transistors will be four pairs of IRFZ44... think it would be enough!? Just find right resistor (RT input) to get 35khz
Please sorry for my stupidity... just starting with smps!
500W offline SMPS mag Power Supplies 99 12th June 2009 11:37 PM
Offline ~500W SMPS VEC7OR Power Supplies 33 25th December 2006 11:54 PM
Selfoscillating HalfBridge 500W+500W by IR. Interested? deflorator Class D 0 10th October 2004 03:30 PM
500W amp Diode Solid State 37 21st March 2003 12:29 AM
Page generated in 0.12430 seconds (74.35% PHP - 25.65% MySQL) with 11 queries
