Guys,
Is there a tool that is used for removing those black clips used to securing tranistors/mosfets to heatsinks? I have a few that I made, but doesn't do the trick for all the amps I service. Tom |
#2 |
Available at Home Depot for about 6 dollars. Brand name Husky. Name of tool, cotter key removal tool. It is a 90 degree hook that with very simple modifications works great.
grind the sharp point off 1/32 of an inch. Stick the tool into a clip, notice where the top of the clip hits the tool and grind a flat spot there. Then notice where the bottom of the clip touches the bottom of the tool and grind a flat spot there too.
If it ain't broke Don't fix it |
| Vcr tv tuner removal of | foxdonovan | Parts | 2 | 20th February 2005 09:49 PM |
| Need help of heat removal. | GeDeon | Pass Labs | 2 | 10th May 2004 09:04 PM |
| 50 or 60 hz hum removal from WAV (+) | VEC7OR | Everything Else | 2 | 11th March 2004 05:39 PM |
| Page generated in 0.06608 seconds (57.81% PHP - 42.19% MySQL) with 10 queries |
