diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Car Audio (http://www.diyaudio.com/forums/car-audio/)
-   -   SoundStream Reference 604 help (http://www.diyaudio.com/forums/car-audio/104251-soundstream-reference-604-help.html)
audiobahnkid592 27th June 2007 04:53 AM
2 Attachment(s)
I just got this amp out of a vehicle that burned down. Long story short it doesnt work. I get the green and yellow LED's on when the switch is in the "high Current" mode and red in the "High Power" mode. The resistor shown in the pic is smoking. Also the board was black from soot so i cant tell if anyhting is in fact burned.
valterdaw 27th June 2007 01:15 PM
Start from cleaning it up with alcohol or acetone. Carbon is very conductive.
audiobahnkid592 27th June 2007 03:48 PM
does anyone have the schematics?
audiobahnkid592 27th June 2007 05:05 PM
2 Attachment(s)
spend a few hours cleaning it up and here is what i have
audiobahnkid592 27th June 2007 05:06 PM
2 Attachment(s)
I think this should be clean enough tell me what you think.
jleaman 27th June 2007 06:22 PM
Looks like its pretty burnt, some of those parts tollerances might be shot due to heat tho.
audiobahnkid592 27th June 2007 07:40 PM
after cleaning it i get the same resistor smoking green or protection
audiobahnkid592 28th June 2007 09:56 PM
power supply mosfets and restitors realy hot. short somewere or bad parts?
jleaman 28th June 2007 10:09 PM
Dead Amp throw in garbage.
1moreamp 28th June 2007 11:46 PM
Shorted and have you replaced all the caps and coils that have been removed off the board, they are the power supply by the way, and you should never run this amp out of its case as a sink for the heat build up on the transistors. you will finish whatever the fire did not by not having the sink attached to the board correctly
The amp is worth maybe 200 or 300 bucks in perfect condition, and you will never see that by repairing it, so WHY fiddle with it?
I do this professionally all day long and I would scrap it, or use it as a door stop, But don't think it will ever be right for little money, as it got well toasted in the fire.
Transistor deplore heat and well you have a well baked amp here with a very unhealthy dose of carbonized build up probably shorting out a lot more than you can see.
Sorry mang, but your spinning your wheels on this one:bigeyes:
PS I am saving your pics you post for my clients as a " Does you amp look like this, sort of thing"
Copyright 1999-2017 diyAudio
