Go Back   Home > Forums > General Interest > Car Audio
Old 23rd June 2007, 04:08 PM   #1
packer is offline packer  United Kingdom
Default BOSE Schematics DENSO Schematics
Hi Guys,
I Have a 2002 Cadillac Seville with the Bose Premium system installed and DENSO Head unit.
Could anyone help with a Source for schematics & or repair on these?
Old 24th June 2007, 01:15 AM   #2
MadMutt is offline MadMutt  Australia
Let me guess, the speakers are hissing and crackling.
Remove the bose amp and rebuild it with new capacitors.
If your lucky the old caps won't have been leaking for long and won't have damadged other ic's.
As for getting diagrams for the bose amp, forget it.
Unless you work for bose or the actual manufacturer your chances of getting any info is next to zero..
Old 24th June 2007, 12:39 PM   #3
Nope the Amp is working ok, I am not happy with EQ curve in the car and I would like to alter it. (assuming it's not done using a serial bus)
the amp is the Bose UX9 option.
Old 24th June 2007, 12:57 PM   #4
Really ?! It's working, well I'll be.
I'm not familiar with the car (well der, I'm from another country).
So I can only go on what I have seen/worked on.
(corvette/camaro/mercedes)
The amps have active crossovers built in and could only be changed by component replacement.
As for any eq filtering, sorry, your on your own.
I have seen an 'interceptor' made by I think it's audio control.
It allows you to feed the headunit signal into it and then do correction, adjustment before it gets sent to whatever amps.
Just had a quick search, maybe something like this
http://www.caraudiomag.com/testrepor...ty2_processor/
Old 24th June 2007, 01:58 PM   #5
WOW!
This is exactly what I have been looking for! What a Awesome piece of gear. Just reading the first paragraph was enough to convince me.
now if only they had an external MIC for RTA oh well....
Right, Let the search begin for one in the UK
Thanks so much for the help
Have a great day!
Old 24th June 2007, 02:49 PM   #6
Send a message via AIM to ocool_15 Send a message via Yahoo to ocool_15
JL audio also has similar OEM interface products called CleanSweep.
OEM Interface
Old 25th June 2007, 11:55 AM   #7
OEM Interface
Thats the one I was thinking off.
Oh well, hopefully the RF will suffice.
Only complaint I'd have with it is the sub xover needs to go lower.
I mean 50Hz, pft come on, I'm running a single 8" at 40Hz xover.
If I have helped then I am happy.......
EDIT, Speeling mistooks......
Here's the W-5M schematics . . . ltarini Tubes / Valves 1 16th October 2007 05:13 PM
still looking for schematics...... unclejed613 Solid State 1 7th February 2007 03:13 PM
BOSE Schematics DJ_ITHEN Solid State 0 28th September 2006 05:46 AM
NAD 302 schematics? showdown Solid State 3 21st October 2005 04:33 AM
amp schematics cess308 Car Audio 7 28th October 2004 06:34 PM
Page generated in 0.11054 seconds (78.76% PHP - 21.24% MySQL) with 10 queries
