Go Back   Home > Forums > General Interest > Car Audio
Old 20th June 2007, 02:51 PM   #1
Default Cleaning Up Old Metal Chassis?
Has anyone ever cleaned the chassis of a classic car radio? If so what products work for you to remove the blemishes and "old" appearance of them? I've used Brasso,Old No.7 chrome/metal polish, Tarnite etc. and they all work to an extent. Just curious as to another product which might do a better job?
Thanks!
Old 20th June 2007, 05:17 PM   #2
Sonusthree's Avatar
It sounds as if you've done all that you can without a respray.
You've cleaned the surface, removed a thin layer of the surface finish and what lies underneath is still affected by years of U.V. photodegradation and other effects associated with age.
What's the problem? Does it look faded, dull, discoloured,uneven or dirty?
Martin.
Old 20th June 2007, 05:23 PM   #3
Hi Martin,
I just came up with an idea! A wire wheel for my drill motor ought to clean that chassis up some more.
Yeah, after I clean the case there are still "age" marks in the metal. Stuff that won't clean up with my regular metal cleaning polishes. The wire wheel would take the metal down some to hopefully take those "age" marks out.
Old 20th June 2007, 05:28 PM   #4
Sonusthree's Avatar
Aaah, sorry! I assumed that the metal chassis was painted.
I'm not sure what you mean by 'age marks'. Will you be painting the chassis or finishing in some other way?
Old 20th June 2007, 05:34 PM   #5
I don't think the chassis was painted originally. I'm just taking it back to bare metal then I'll coat it with WD-40 or something to protect it
The age marks I mentioned are left once rust has been removed etc.. It leaves dark spots on the metal. I'm thinking the wire brush would remove them. What do you think? Worth a try, eh?
Old 20th June 2007, 06:50 PM   #6
The original metal was likely galvanized. This (link below) should return it to a near original look and protect it much better than WD-40 or similar coatings. You'd need to clean the surface with a strong solvent like acetone to remove the silicones/waxes left by the cleaners you used.
http://www.rustoleum.com/product.asp...ct_id=28&SBL=1
Old 20th June 2007, 07:05 PM   #7
Awesome, thanks Perry I'll check the site!
Old 22nd June 2007, 03:23 AM   #8
Martin.
Hey Martin and Perry, The more I clean this chassis the more I'm starting to realize that maybe it WAS painted from the beginning. The least these Americans could do to protect the radios. Too bad they couldn't have done something to keep the cowls from leaking rain water and car washes INTO the radio to begin with!
I'm going to find that cold galvanized compound Friday and give that a shot to finish this chassis off. I'll let you guys know the outcome.
Thanks again!
Steve
Cleaning Rust and corrosion of metal parts?? Zero Cool Everything Else 3 26th October 2008 12:12 AM
Where to buy metal prefab chassis? marchewd Parts 9 21st February 2007 11:44 PM
Where to buy metal prefab chassis? marchewd Vendor's Bazaar 0 17th February 2007 07:40 AM
Wooden chassis vs. metal Thomas B Pass Labs 32 29th December 2002 06:21 AM
Page generated in 0.09178 seconds (85.78% PHP - 14.22% MySQL) with 10 queries
