Ppi Pc450 - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 21st June 2007, 12:33 AM   #11
Shaft is offline Shaft  United States
So if I replaced it with the TIP42, what will happen? It will eventually blow?
Old 21st June 2007, 06:09 PM   #12
If you use a TIP42, it could blow before the end of the first song if you drive it hard into a 2 ohm load. If you only use it to listen to talk radio at a low to moderate level, the TIP42s may survive for years.
Order the correct parts. The total will likely be less than $10 including shipping.
http://www.mouser.com/search/Product...key863-2N6491G
http://www.mouser.com/search/Product...key863-2N6488G
Old 21st June 2007, 06:31 PM   #13
You got a point there. The channel that has the blown transistors I use for bass, 4 ohm mono <which is the same as 2 ohm stereo>. I could swap the chips from channel 1, since those I would only run 4 ohm stereo for mids and highs.
We'll just see. The TIPs came in today so I'll play with it after work. If I things don't work our right, oh well. The fun of it is learning how this whole thing works.
Thanks for all you're help. I'll let you know what happens.
Old 21st June 2007, 06:59 PM   #14
If you were lucky, only the outputs failed with no damage to drivers or the power supply. If it blows again, it may do MUCH more damage. You can use the 42s to determine if there is other damage to that channel (defective drivers...) but I wouldn't do more than that.
Old 22nd June 2007, 04:05 AM   #15
I put the 42's in and it is still doing the same thing. I wonder if there is some power supply damage.
I e-mailed one of our technicians that works in the repair center and will see what else he can tell me.
Of course the easiest and cheapest thing for me would be to employee purchase me an Eclipse amp.
Old 25th June 2007, 03:42 AM   #16
It may have defective drivers or the 88s could be defective (but not completely shorted). If you're interested in learning a bit more, you may still be able to repair it. If you simply want a working amp and can afford to buy a new one, that may be a better option for you.
Old 30th June 2007, 03:26 PM   #17
ppia600 is offline ppia600  United States
Wow, I didn't know the nte cross would be crappier. They (nte) always brag about their crosses being as good or better than the original. Is this only in some cases? I do notice the cases of the nte crosses looking poorly made sometimes.
Old 30th June 2007, 10:47 PM   #18
What would say if your were selling crap ?
Do as Perry says and use original parts only and your life will become a smoother trail. I have been doing this myself for over 20 years and both Perry and I know from real life experiences original parts rarely let you down
Old 1st July 2007, 07:51 AM   #19
I've repaired a few amps, maybe thirty in the time I've been learning. Most of the time they were simple problems like bad solder joints or outputs or power supply transistors. I like working on american made amps (the older ones) and the alpine, sony and kenwood seem to be pretty straight forward and easy to repair.
Old 12th June 2015, 06:27 AM   #20
dmuney is offline dmuney  United States
Originally Posted by Perry Babin View Post
Try digikey.com or mouser.com.
If the amp uses two 88s and two 91s per channel, you should replace both the 88s and 91s in the defective channel.
There's a good chance that only one of the 91s is damaged. If you pull one and find that only one is defective, you can reinstall the good one and test it at low power to see if there are any other problems. If it plays cleanly, you can replace the 88s and 91s and likely be done. If it's still distorted or goes into protection when the defective transistor is removed, there may be defective driver transistors.
Remember, you need to replace the bottom cover before applying power.
Hello perry I have a pc4400.2 with a simpler problem q69 q70 q72 q73 appear defective have almost no resistance between pins 1 and 2 also the emoter resistors appear bad also I could use your help if you have time
Sent from my iPad using Tapatalk
Flexin 98 4dr civic with PPI Powerclass and Sundown Audio
PPI ART Series a404 "v" PPI Powerclass pc450 swap chemhaz Car Audio 2 21st November 2008 02:23 PM
Ppi Pc450 AHROBERTS Car Audio 4 20th October 2007 03:22 AM
Disabling cross overs and bass boost on ppi pc450 geom_tol Car Audio 5 26th July 2007 01:05 AM
ppi pc450 problems jordan_ciaramit Car Audio 4 14th November 2006 03:07 AM
Copyright 1999-2017 diyAudio
