IRF640 vs IRF640N
IRF640 vs IRF640N
Old 15th June 2007, 08:08 PM   #1
Tom7227 is offline Tom7227  United States
Tom7227's Avatar
IRF640 vs IRF640N Send a message via AIM to Tom7227
Question IRF640 vs IRF640N
I hope someone has input, or perhaps experiance with this.
I have a Fusion Amp with 1 bad IRF640 output MOSFET.
Power supply was destroyed and after hours of endless troubleshooting, got it running.
Problem is I have all kinds of 640N's and NO 640's..
Whats the opinion of mixing these?
I know the 640N is the lead free version...
Tom
Old 15th June 2007, 11:36 PM   #2
KyferEz is offline KyferEz  United States
I'd say replace all of the supply fets w/ the 640N, otherwise you are likely to have trouble. Why? because of a slightly different manufacturing process, and differing date code of the parts.
Even identical parts should be from the same "batch" when replacing FETs used in parallel.
My 2 cents.
KyferEz
Old 15th June 2007, 11:41 PM   #3
Tom7227's Avatar
Thank You,
I was able to find one IRF640.... Install it and worked good..so far.
I was trying to avoid replacing (20) 640's... to 640N's
perhaps if this comes back.. I will have to change them all.
Old 16th June 2007, 08:03 AM   #4
1moreamp is offline 1moreamp  United States
Theres a simple fet tester over in the Pass forum section that will let you at least try to match ON characteristics enough that you will at least be in the ball park when replacing Mosfets in array's.
I have never found date codes that reliable as a matching guide, but others here disagree with me on this saying it has worked well for them. So its sorta a question of time and money.
Guess I am old fashioned about matching semi's. I would at least try to get the nomenclature the same and the same maker of course, Or just replace the whole bunch with the same exact part from the same maker for symmetry if nothing else. IRF-640's are fairly cheap in quantity's that I buy. They cost like 18 cents each purchased in bulk quantity's.
Good luck on your repairs
Old 16th June 2007, 06:49 PM   #5
Where are you buying them from?
At 1000 qty they are $0.74 at mouser. Digikey has 640N for $1.47 or 640PBF for $0.58.
Old 16th June 2007, 10:09 PM   #6
Tom7227's Avatar
Perhaps the question is not beta matching,
BUT, what is the characteristic change with a "leaded" vs NON leaded semiconducter?
Old 16th June 2007, 10:19 PM   #7
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
IRF640 vs IRF640N
The difference is not lead or lead-free at all, the N suffix is simply a later replacement using newer technology to achieve a smaller die size. Hence the N suffix cannot take as much power when used in linear mode.
There is a document on the IR website that explains it all.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
IRF640 vs IRF640NHide this!Advertise here!
irf640/9640 in amplifiers Flavio88 Solid State 8 25th March 2011 12:39 PM
ir2110 and 6 x irf640 per side? jake83 Class D 8 4th March 2007 01:08 PM
Is IRF640 useful.. skaara Pass Labs 5 3rd November 2003 04:27 PM
Using IRF640N's in Balanced Zen Preamp ajhawkins Solid State 1 31st December 2001 07:24 PM
Help on IRF640 and IRFP240 ! ghee0 Solid State 3 1st September 2001 02:10 PM
