Wiring HU X over and amps - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 6th June 2007, 07:01 PM   #1
Bad silver's Avatar
Default Wiring HU X over and amps
Hi I am reviring my sound system. I want to add a second battery in the trunk that is going to be connected to cars’ electrical system only when ignition is in “ON” position. My question is whether I should power my Head Unit and electronic crossover from OEM battery and power my amplifiers form the battery in the trunk. Or, should I connect everything (HU, crossover, amplifier) to the battery in the trunk. Thanks.
Old 7th June 2007, 04:06 AM   #2
Bad silver's Avatar
Can I put the relay like in the diagram 1) on the attached image? If the voltage difference between 2 batteries is 5 volt and the switch is open can the current start flowing in reverse through amplifiers, head unit, and crossover bypassing the switch?
Which diagram is better? How should I wire if 2 batteries have different capacities?
Big sale thread: PHL, Raven, Amps, In-wall/ceiling speakers, Amps, VideoRequest mbcouple Swap Meet 2 27th October 2008 10:27 PM
Wiring 2 Dual Voice Coil Subs To 2 Amps BEAN27 Car Audio 1 14th April 2006 11:23 PM
basic wiring for t-amps HELP! miles488 Chip Amps 3 6th February 2006 08:41 PM
Focusing on wiring cable for gainclone!!!Share ur experience in wiring cable.... thomgun_lc Chip Amps 38 31st August 2005 02:46 PM
I'm wiring my 4 channel 8 parallel LM4780 boards... check my wiring :) Audiophilenoob Chip Amps 9 16th August 2005 04:37 AM
Copyright ©1999-2017 diyAudio
