I have a Lanzar 4000 watt 2 channel amp and i am getting engine noise through my speakers does anybody know what can be causing this problem please help
#2 |
diyAudio Moderator Emeritus
Noise from your alternator is being coupled into your signal wires. Do you have the input wiring running right next to the power wire? Is the amp's ground connection electrically and mechanically solid?
Brian |
#3 |
As stated above make sure you RCA's are NOT near the power wire also good, solid grounds are a must.
#4 |
Pioneer Radio?
If it ain't broke Don't fix it |
#5 |
yes i have an pioneer head unit
#6 |
If your engine noise is very loud, chances are the problem is the shield of your RCA cables have lost their ground refference.
To make sure this is your problem we need to remove our radio from the dash so we can get to the RCA cable that goes to the amp. Then we need to take a length of small wire a couple feet long, we need to ground one end of the wire and with the engine running and noise present, touch the other end of the wire to the outer part of your RCA cable. The shiny part you can still see when the cable is plugged into the deck. This should make a little pop and the noise should go away. If this gets rid of the noise let me know and we can help you get it repaired.
#7 | |
tried it and the noise is still there i even tried different rca's my ground wire is an 8 gauge |
#8 |
your ground is bad some where in the car and have you done the big 3 yet ?
#9 | |
whats the big 3 |
#10 |
do you get the noise with just one RCA connected?
| engine noise - bad amp?? | Dan2 | Car Audio | 43 | 5th November 2008 10:26 AM |
| engine noise problem, HELP!!!! | TheStape | Car Audio | 2 | 14th November 2007 05:29 AM |
| Engine noise (tried almost everything) please help! | wally91chevrole | Car Audio | 34 | 26th February 2006 06:41 AM |
| engine noise HELP! | st33lownz | Car Audio | 6 | 4th November 2004 07:35 PM |
| noise in right speaker when engine on | crazyinjun | Car Audio | 13 | 7th May 2004 12:34 AM |
| Page generated in 0.11193 seconds (78.82% PHP - 21.18% MySQL) with 10 queries |
