Go Back   Home > Forums > General Interest > Car Audio
Old 2nd June 2007, 03:27 AM   #21
Sorry it took us so long to help you. Next time if you would list all components of your system it would really help.
If it ain't broke Don't fix it
Old 2nd June 2007, 05:27 AM   #22
zzzzzzz is offline zzzzzzz  Canada
Originally posted by makaveli956
whats the big 3
i would use 0g wire for this
1. power wire to the alternator
2. ground wire fron the battery to the chasis
3 ground wire from the Engine block to the chasis.
add a ground to your deck and add a ground to the rca's at the deck (your deck is knowen for this too ) but i would try this frist
Old 3rd June 2007, 12:58 AM   #23
I have tried everything is it by chance that the 4000 watt amp could be causing me my problems
Old 3rd June 2007, 03:02 AM   #24
According to the last post on the 2nd page of this thread, you said you grounded the RCA cable at your crossover and the noise went away.
Or did I read that wrong?
Old 3rd June 2007, 03:05 AM   #25
right i grounded my 4000 watt rca and the noise went away and i also grounded my highs amp and the noise went away
Old 3rd June 2007, 03:22 AM   #26
The problem is your crossover. But if you grounded the shield of the RCA cables and the noise went away, maybe you need to solder a wire to the cable and ground the other end of it.
Just a hunch, but it might fix it.
If you want to repair your crossover it will not be that difficult. The problem is a burnt trace on the circuit board. The trace connects the input RCA jack to the output RCAs.
Old 3rd June 2007, 06:40 AM   #27
i tried a different crossover still the samething i think it's the amp because i hooked up another amp and i do not have any engine noise
engine noise - bad amp?? Dan2 Car Audio 43 5th November 2008 09:26 AM
engine noise problem, HELP!!!! TheStape Car Audio 2 14th November 2007 04:29 AM
Engine noise (tried almost everything) please help! wally91chevrole Car Audio 34 26th February 2006 05:41 AM
engine noise HELP! st33lownz Car Audio 6 4th November 2004 06:35 PM
noise in right speaker when engine on crazyinjun Car Audio 13 6th May 2004 11:34 PM
Page generated in 0.09026 seconds (75.35% PHP - 24.65% MySQL) with 10 queries
