Go Back   Home > Forums > General Interest > Car Audio
Old 6th May 2007, 09:20 PM   #1
Default 1993-Vintage PPI Amp Specs needed
Having searched the forums to the best of my ability and not having found anything, I'm starting this thread. I have 2 PPI amps from 1993 or thereabouts... one A100 Art Series and one APA200ix Sedona. I'm fairly sure about the Sedona specs as I've used it recently to put 200W through 4 Ohms-worth of subs, but wouldn't mind a full spec listing. I can guess, please correct or fill in the blanks:
- 2 x 100W @ 4 Ohms
- 2 x ???W @ 2 Ohms
- 1 x 200W @ 4 Ohms
As for the A100, I can only guess based on some specs that I found that may or may not apply to this amp, please correct or confirm:
- 2 x 50W @ 4 Ohms
- 2 x 75W @ 2 Ohms
- 1 x 100W @ 4 Ohms
I would appreciate any help as I came into these beauties without the manuals.
Nate
Old 7th May 2007, 11:00 AM   #2
I am not familiar with these particular amplifiers but I can tell you that the 100 IS rated at
2x50 at 4 ohms which would be 1x100 at 8 ohms
The 2x75 at 2 sounds about right but this would translate to 1x150 at 4 ohm
As for the 200 if using the same math for it
2x100 at 4
1x200 at 8
2x150 at 2
1x300 at 4
If it ain't broke Don't fix it
Old 8th May 2007, 10:25 PM   #3
Having actually seen the 200ix manual at some point in time, I'm pretty sure it is rated at 1 x 200W @ 4 Ohms when the 2 channels are bridged, and that is actually what I have used it for. Not too sure about your math or assumptions on some of the stuff...
Old 9th May 2007, 04:58 AM   #4
The math is correct. An amps 4ohm bridged power is the same as the sum of it's 2 stereo channels at 2ohms. Thus 75x2 at 2ohm = 1x150 at 4ohm. The question is... What is the 2ohm stereo power per channel? Some amps double, some amps gain no power at all. It depends on the design... How regulated the power supply is...
Old 1st June 2007, 08:59 PM   #5
imnhell is offline imnhell  United States
I have a PPI brochure from a long time ago, not really sure of the date. On the back page there are specs, yours are as follows:
A100.2
stereo 4 ohms, 11 - 15 vdc, 2 x 25 watts
stereo 2 ohms, 11 - 15 vdc, 2 x 50 watts
bridged, 4 ohms, 11 - 15 vdc, 1 x 100 watts
power fuse, 30 amp
200iQx
stereo 4 ohms, 14.4 vdc, 2 x 100 watts
stereo 2 ohms, 14.4 vdc, 2 x 165 watts
bridged 4 ohms, 14.4 vdc, 1 x 330 watts
power fuse, 35 amp
John
Old 2nd June 2007, 09:13 AM   #6
Send a message via ICQ to junglejuice
With the art series amps the model number is the total power at 2ohms therefor a 100 is 2x50 @2 the 200 was 2x100 @2 etc....
Vintage Mcintosh MC250 help needed!! Mr. p-car Solid State 38 8th January 2007 08:56 PM
Sony speaker specs needed wolly Multi-Way 0 4th April 2006 11:13 AM
Grace 727 specs needed Phydeaux Analogue Source 14 9th July 2005 02:31 PM
Needed specs for PIONEER 15'' exurbia Multi-Way 3 28th June 2004 02:33 AM
TRIAD specs. needed! Fuling Tubes / Valves 0 23rd September 2003 01:56 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright Đ1999-2013 diyAudio
