PCX1250 2ohm mode Problem - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 14th April 2007, 11:50 PM   #1
Exclamation PCX1250 2ohm mode Problem
Hello all,
I have been having troupbe with my amp. The PCX1250 works fine with either 4 ohm sub but when connected together for a 2 ohm load on the amp the sound level is low and distorted. since both subs work fine connected on their own I have to assume that there is a problem with the amp. Has any one else ever had such an issue? I do failure analysis on power supplies for a living so I'm sure fixing the amp would not be a problem just hoping someone might have some insight into what the root cause is for this failure mode.
Old 15th April 2007, 03:26 AM   #2
Check the 0.1 ohm 5 watt emitter/source resistors to see if any have broken leads.
Using a spdt switch to select between triode mode and pentode mode on a guitar amp. G Instruments and Amps 19 15th March 2006 10:15 AM
LC Audio Zapsolute "Power Down Mode" Problem syscall Solid State 1 22nd November 2005 03:53 PM
Calculating watt requirements for multi-mode/tri-mode operation? Datoyminaytah Solid State 1 14th August 2004 08:43 AM
2ohm rulezzz Chip Amps 4 25th January 2004 12:21 AM
How's about a Depletion Mode / Enhancement Mode CCCS MIKET Tubes / Valves 9 11th September 2003 04:44 PM
Copyright 1999-2017 diyAudio
