New Lateral MOSFETs Just Released! - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Aussie Amplifiers
Aussie Amplifiers High quality, high performance amplifier modules and accessories
Old 11th February 2007, 11:11 PM   #11
These New MOSFETs have been designed to be a broadspectrum
replacement for all of the available Lateral MOSFETs on the market today and to be supplied at much cheaper prices than you would normally expect to pay.
They have also been designed to handle more power than the current range of Lateral MOSFETs available on the market place.
The Single die versions are rated at 10 amps
One of the added features of these Lateral MOSFETs is the placement of an internal 15 Ohm Gate resistor.
Which is etched into the silicon die, right on the GATE.
This aids in improved stability of the device which is not found in any other lateral mosfet.
Old 12th February 2007, 12:31 AM   #12
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
European distributor?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 12th February 2007, 12:38 AM   #13
EU Distributor
www.class-d.com
Old 12th February 2007, 12:45 AM   #14
Twenty years ago I had read in some Hitachi's papers, that internal resistance of gate is ( as I remember ) about 30 Ohms, 'cos aluminium traces on die are very thin...so nothing new under the Sun, Anthony....
Old 12th February 2007, 12:53 AM   #15
That my well be so but we have added an additional gate resistor
into the die its self and increased the channel width for increased current capability.
Old 12th February 2007, 12:56 AM   #16
Zen Mod's Avatar
Originally posted by The Saint
EU Distributor
www.class-d.com
Old 12th February 2007, 01:50 PM   #17
rlg_200 is offline rlg_200  Philippines
Default hexfet to Lmosfet
Hi Anthony,
Can I Use Lateral Mosfet like 2sk1058/2sj162 instead of Hexfet irfp240/irfp9240 in your av400/av800 design?
rlg
Old 12th February 2007, 05:33 PM   #18
Hi Rig
Yes you could use Lateral MOSFETs in the AV400 and AV800 designs, but not with the existing PCBs.
The pinouts on the Laterals are swapped between Drain and Source.
However I will be releasing 4 x new designs based on my NX150
that are going to replace the AV400 and AV800 amplifier modules.
They will be the NX400 Synergy, NX500NL and NX800NL/NX1000NL.
All of these designs use lateral mosfets.
The NX400 uses Dual die N and P mosfets, while the NX500NL and NX800NL/NX1000NL are all N-channel designs.
Old 12th February 2007, 06:32 PM   #19
paulb is offline paulb  Canada
So these should work for
http://sound.westhost.com/project101.htm
Old 12th February 2007, 08:03 PM   #20
Hi Paulb
Yes they will, A drop in replacement
Ode to Lateral MOSFETs Lumba Ogir Solid State 53 28th January 2017 10:24 AM
Lateral Mosfets for sale Fanuc Swap Meet 20 28th March 2009 10:17 AM
Substitute Lateral Mosfets joensd Parts 33 21st December 2008 01:57 PM
Lateral mosfets - why ? Stormo Solid State 5 2nd July 2003 07:14 AM
Lateral Type Mosfets Diogo Solid State 4 30th September 2002 08:11 AM
Copyright 1999-2017 diyAudio
