Another NXV-500 r2! - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Aussie Amplifiers
Aussie Amplifiers High quality, high performance amplifier modules and accessories
Old 12th April 2014, 01:15 PM   #1
palmito is offline palmito  United States
palmito's Avatar
Default Another NXV-500 r2!
I've been gathering the parts for over six months (buying things as budget allows). I finally had everything I wanted but the case. I wanted to put the heatsinks inside the case, so I had Parmetal make me a custom sized case. It turned out looking a lot bigger in real life than in paper...
I debated whether to build the amp or rent the case as a small apartment to a graduate student.
But I finally got the case late this week. Work has gotten very busy so this will be a slow build. But here's the photos of the case and the parts.
Old 14th April 2014, 12:06 AM   #2
Hey Frankie
Great to see you have made a start on your nxV500 R2 stereo amplifier.
Please continue to post your progress with lots of photos.
I will look forward to seeing how it turns out.
Cheers
Anthony
HPA
Old 14th April 2014, 01:21 AM   #3
palmito's Avatar
Hi Anthony! Better late than never...
Having the Volt One and the extra transformer did make layout a bit harder. I probably should have gone for two Volt Ones as you suggested just for ease of laying things out.
I will keep posting photos of the build.
Thanks for a the great support!
Old 23rd April 2014, 02:04 AM   #4
palmito's Avatar
Default I have a layout question!
I'm planning on placing the power supply boards (and volt one) over the toroids, using a diyaudio store amplifier chassis bottom (the thick metal ones). The metal sheet is magnetic (steel, not aluminum). See the photo below.
Is the metal base enough shield to protect the ps boards from being so close to the top of the toroid (where the stray fields would be strongest I think)?
I could place the metal sheet perpendicular to the position in the photo so I can slide the ps boards away from the toroids and only the rectifier portion of the ps boards would be above the toroids. Would this be a better arrangement?
Or the boards are shielded by the metal sheet?
Or is using the steel sheet a bad idea (use aluminum instead)?
Thanks in advance for any suggestions.
Old 10th May 2014, 12:04 AM   #5
palmito's Avatar
Default Some more progress...
The cnc shop drilled the xlr connectors crooked... I tried fixing the holes but didn't get them completely square, but it lools better. I know it doesn't affect the sound, but I just wanted them to look a bit better.
Put the feet and trafos. Ended adding one more foot to the chassis in the between the three trafos, it's a lot of weight.
Put in the AC controlling boards.
Added the "second floor" for ps boards.
Old 25th May 2014, 12:38 AM   #6
palmito's Avatar
Default More progress...
I fixed the AC control parts. Had a problem with the HPA-Power-One, so for testing I'm leaving it out of the wiring.
Drilled the "second floor" metal plate and ran trafo wires through the holes.
Fixed the metal base and heatsinks with amp boards, started wiring the power supplies to the amp boards.
Forgot to mention I tested the power supplies and all tested ok (no load output) and I set the Volt-One output to 80v, no load. Will readjust, per Anthony's instructions, after the amp boards are connected.
Old 26th May 2014, 12:22 PM   #7
emyeuoi is offline emyeuoi  Italy
emyeuoi's Avatar
Good progress Palmito
This "second floor" remember me my F5T v2
Old 9th December 2014, 08:27 PM   #8
Frazzled's Avatar
Any progress on this?
Anything worth trying is worth failing at once or twice.
Old 12th December 2014, 02:54 PM   #9
I guess not
Old 12th December 2014, 03:25 PM   #10
palmito's Avatar
Default Sorry
Sorry guys. It is finished and has been burning in for about a month. I will post the final photos and a review in the next couple of days.
Building a NXV-500 r2 ijscobar Aussie Amplifiers 117 2nd September 2016 07:31 AM
Max voltage for NXV 200 R 3 input section. Erlend Sæterdal Solid State 0 15th July 2013 03:52 PM
NXV-1200 Build Complete tjencks Aussie Amplifiers 3 30th September 2012 09:39 AM
nxV recommendation for Magnepan MG 3.7 dvb projekt Aussie Amplifiers 13 19th December 2011 08:39 AM
HPA NxV 550 or more Jman554 Aussie Amplifiers 2 10th November 2009 09:04 PM
Copyright ©1999-2017 diyAudio
