Go Back   Home > Forums > Commercial Sector > Manufacturers > Aussie Amplifiers
Aussie Amplifiers High quality, high performance amplifier modules and accessories
Old 6th January 2014, 07:00 AM   #41
The transformer story...
First pic is the set up with 2 NTC's.
Then the multimeter is set in the 20VAC range.
Pics of transformer 1 to 4. The transformers with the connectors were used in the amp and lived for a short while... One faulty transformer is rare. Four faulty transformers is a miracle...
Old 6th January 2014, 08:27 AM   #42
Originally Posted by ijscobar View Post
How are your NXV's doing?
I have not much spare time, but started disassembling my Hawk A-50 mono's and will be using those cabinets, transformers and heat sinks. Those transformers do 2x 27 VAC. Could be a bit more, but will be enough to be able to judge the quality of the amps. They are 500VA each though...
Old 6th January 2014, 08:47 AM   #43
Well, always nice to have working transformers
I think you're in for a pleasant surprise when you fire up your amps for the first time!
Old 6th January 2014, 10:32 AM   #44
Pfff... This seperates the man from the boys...
The transformers. What did I do wrong.
I used the secondary windings like this. In my mind, two wires (red and black) coming from the same spot, belong together. (see picture)
Old 6th January 2014, 10:33 AM   #45
But I should have done this. (see picture)
Old 6th January 2014, 10:34 AM   #46
The strange thing remains that I used the wrong combination and the amplifier worked...
Old 6th January 2014, 10:35 AM   #47
I will now stop building audio-equipment and start collecting stamps...
Old 6th January 2014, 10:37 AM   #48
_henry_ is offline _henry_  Australia
good to hear that you can play the amp again .
i've heard the nxv-300 and nxv-203PS, the 300 was good, but the newer 203PS is better. i cant tell the difference in 15mins i put them in my system with nc400.
the nxv300 was noticeably warmer and bloated bass, but the 203 is clean and mean
Old 6th January 2014, 10:46 AM   #49
Thanks, but I have to wait a while before I can play again because I just sent the HYPEX PS back to them for repairs.
For me the difference between the NXV500r2 and NXV200 short form is quite simple. The NXV500 does everything better than my NXV200. But if your speakers are not as powerhungry as mine you will have an absolutely magnificant amp if you buy a NXV200!
Old 6th January 2014, 12:11 PM   #50
I see the picture is missing. Let's try again...
Max voltage for NXV 200 R 3 input section. Erlend Sæterdal Solid State 0 15th July 2013 03:52 PM
NXV-1200 Build Complete tjencks Aussie Amplifiers 3 30th September 2012 09:39 AM
nxV recommendation for Magnepan MG 3.7 dvb projekt Aussie Amplifiers 13 19th December 2011 08:39 AM
HPA NxV 550 or more Jman554 Aussie Amplifiers 2 10th November 2009 09:04 PM
FS: JL 500/1 ($500 CAD located in GVA) Dynamix Lude Swap Meet 0 27th October 2004 03:21 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright ©1999-2014 diyAudio
