Go Back   Home > Forums > > >
Aussie Amplifiers High quality, high performance amplifier modules and accessories
Old 16th August 2016, 04:46 AM   #151
Leikis is offline Leikis
Back side.
Wisdom L75, ,Holton NXL-50 Anaview AMS-1000
Holton SmartDac, MiniDSP 4x10 HD, MIT750, Monster M1
Old 16th August 2016, 06:59 AM   #152
Erlend Sæterdal is offline Erlend Sæterdal  Denmark
My Holton amp builds.
Looks fantastic Leikis. Would wish I had the patience of making it that way.
Old 27th August 2017, 12:18 PM   #153
androa76 is offline androa76  Slovenia
Some pictures of my work
Old 28th August 2017, 01:08 AM   #154
The Saint is offline The Saint  Australia
Very Nice Work Davorin!
I hope you are enjoying the sound quality?
Perhaps you could express or describe your listening experiences with us as well?
Cheers Anthony
Holton Audio
Old 28th August 2017, 04:55 AM   #155
Thank you Anthony.
I must confess that i was just built your amp... Tried it technically and hear some music trought my small test speakers for safety reason from past. Because of abssent from home i can try it seriously in next days. Btw. Modules are very good production quality and smart design. Assembly is quite simple even for Diy members with less electronic skills. Almost no soldering, just plug and play.
Nice greet Davorin
Old 30th August 2017, 04:02 PM   #156
Amp in action. Sings really beautiful. At bias set to 360mA, it plays extremely rock stable, full and wide in all dimensions.
Everything is on right position, very fast amp but not harsh or thin sounded, more on soft side. Very satisfied. I have done 2 version from FO (1.2 and 1.3) amp, and try it at my place but this amp is much more musically to my ears. More fuller sound more realistic timbre, and not so dry sounded. Excellent design.
Old 31st August 2017, 12:05 AM   #157
Thats Awesome!
Thanks so much for posting your experiences.
Once again beautiful job with the build of the amplifier.
Cheers Anthony
Holton Audio
Old 31st August 2017, 12:55 PM   #158
Mark Verhoeven is offline Mark Verhoeven  Netherlands
Androa76,
Which amplifier modules did you use? Can't find anything looking like this on the Holton website...
Mark.
Old 31st August 2017, 05:43 PM   #159
HPA-nxV101 R2 Signature
100 Watts RMS continuous sine wave into 8 Ω Per Channel
170 Watts RMS continuous sine wave into 4 Ω Per Channel
The HPA-nxV101 R2 is 2Ω Stable
Biased into Class A/B
Power Bandwidth 1,5hz to 660khz -3dB
Dampening Factor At 100hz 8Ω = 800
Dampening Factor At 1khz 8Ω = 650
Dampening Factor At 10khz 8Ω = 250
RCA Single ended Input impedance 33kΩ
Single Ended Input Gain = 30.6dB
Signal to Noise Ratio -110dB
Recommended Linear Voltage Supply +-50 volts DC
Operational Supply Voltage Range +-10v DC to +-60 volts DC
PSU Power Transformer secondary windings 0-35vac + 0-35vac
More infos from Anthony
Nice day Davorin
My Holton amp builds.Hide this!Advertise here!
SSLV1.1 builds & fairy tales Salas Power Supplies 3981 26th August 2017 12:37 PM
Call for MyRef-C Builds & Photos bcmbob Chipamp 0 1st October 2010 10:57 PM
400 watt Holton amp upgrade Mattyo5 Solid State 31 19th June 2003 04:05 PM
Holton N-Channel Amp markkanof Solid State 1 17th June 2002 08:49 AM
Zen Revisited Vs Anthony Holton A/B amp FullThrottleRic Pass Labs 20 27th May 2001 01:29 PM
Copyright ©1999-2017 diyAudio
